20 Most Recent
Sony BRAVIA W-Series KDL-46W4150 46 in. LCD HDTV Questions & Answers
I have a Sony Bravia
Would you please tell me how may blinks it shows? The blink error code will tell you what is the problem.
I have a sony KDL-46w4150 and it is starting to
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Why sony tv has white screen no colour
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I am getting a whitish coloured fast flicker
Hi, You have guessed it right. (tuner fault) I would suggest you can get a set top box, they have tuners built in. Just set your TV on ch 3 or 4 and you can run from the box. You can get them from your cable company or dish network. Good luck.
I have the Sony KDL-46W4150,
Based on serial number of your tv, no firmware update available at this moment on
Sony Support site.
Please switch to component AV cables to avoid intermittent sound problem, I hope a firmware update will be available soon to resolve the sound issue.
Thanks.
Sony KDL46W4150 TV powers on with picture and
It sounds like the power supply is bad.Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
