20 Most Recent
LG Scarlet 42LG6000 42 in. HD-Ready LCD TV Questions & Answers
Lg scarlet
Mainboard failure changing it will solve your problems
Horizontal lines on tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Line faults to LCD TVs are given with illustrations. You can see ie and compare to that of your TVs' screen, and can guess about the fault to an extent. Almost all LCD TVs exhibit the same type of fault, irrespective of its brand and dimension.
Lg tv problems
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
I have a 2 year old LG LCD TV (model 42LG60) and I
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
