20 Most Recent
Haier HL42E LCD TV Questions & Answers
I have problems with my LCD HAIER TV. I put my USB
There should be a button on your remote that says "TV/USB". Try clicking it, that should take you to a blue screen that says No Signal, click Input, and you should be able to access your cable from the list of Input sources. This happened to me today, very annoying and unnecessarily confusing, especially since most buttons you press result in a screen that reads "Not Available." Urrgghhh.
My haier tv model no. hl42e wont come on
HelloIf its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
- Turn on your device (i.e. TV).
- PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
- PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
- ENTER the 5 digit code for your brand from the list above.
- You should receive 2 quick flashes on the LED for the selected device after entering your code.
- PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
