20 Most Recent
FEC RKMV5 Custom Rackmount Kit for JVC RKMV5 Questions & Answers
Dvd movie will no longer play in my dvd player
hi, what you need to try is go out and buy a dvd lense cleaning kit you can buy these from most electrical outlets such as maplin you can also get them online to order, after you get one of these but dont buy a cheap one as they tend not to work, put it in your dvd player this will then clean the lense witch is more than likely giving you the problem once you have done this you should find that it will work properly.
The problem is some dvd's are slightly different and require the laser to work more so this could be causing your error.
Let me know how you get on or if you need further assistance ok
Panasonic DVD playerS35 error H 07
HELLO
H07 is the fault code for the disc motor and here is what you need to do to remedy it.
The cover of the player will have to be removed to do this. Locate the the actual motor shaft and where it goes into the motor itself, put a little drop of light oil or WD40. Let it soak in for a little while and try it again. I'm sure you will find it now works.
I had this problem on Panasonic NV-VP31 DVD/VCR unit and I have had no more trouble since!
HOPE THIS HAS HELPED - ENJOY!
My DVD disc not recognized after loading, how can i fix it?
See if this is just an issue with one DVD. If it is, then the DVD is defective or dirty. If this happans to al of your CD's you should clean the Eye of the DVD player with a special CD you can most likely find on the internet. Just search about the problem you are having.
When I put certain dvd's
that happens when u insert a disc of the wrong region,PAL disc in NTSC only player and vice versa or if the disc is damaged and cant be read..hope it helps!
My Polaroid DVD Portable do not read disc
Using a program called dvdshrink will do the trick. Go to www.fileforum.com, it is free. The problem with dvd's are some say they are listed to ntsc american standard, but some are sometime not done correctly. Follow all the instructions with the software and reburn the dvd without regions. It sould work after that. And it is not illegal to make "backups" of you purchased dvds. Hope this help.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
