20 Most Recent
Kenwood KDC-MP208 Car CD/ MP3 Player Questions & Answers
Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
8/18/2021 7:34:02 PM •
Kenwood...
Answered
on Aug 18, 2021
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do
not need a diagram you need to go purchase the wiring harness for your
make and model and year car. Match the colored wires together to the
ones on the back of the head unit then connect them, then that harness
plugs into your stock car harness that your stock radio unplugged from.
You also probly need an antenna adapter cable that just connects to
your stock antenna cable to add length and then plugs into your
aftermarket radio. If you need a wiring diagram because you are trying
to open you radio and fix it because it is broke or something...good
luck to ya. Hope I helped... :)
11/16/2013 7:04:03 PM •
Kenwood...
Answered
on Nov 16, 2013
Kdc-mp208
This is usually ground problem. check ground wire
1/20/2012 3:14:24 PM •
Kenwood...
Answered
on Jan 20, 2012
Wheres the loud button
If you press and hold the aud button for a few seconds it should take you to the audio menu. If you scroll through it you should be able to turn loudness off and on.
10/11/2011 5:05:04 PM •
Kenwood...
Answered
on Oct 11, 2011
What colors are ignition
Ignition wire for the radio is RED.
The constant 12v is YELLOW.
BLUE is the remote/power antenna.
ORANGE is for the dimmer.
PURPLE pairs are right rear speakers.
GREEN pairs are left rears speakers.
GRAY pairs are right fronts and
WHITE pairs left fronts speakers. Hope this helps.
5/19/2011 7:18:49 AM •
Kenwood...
Answered
on May 19, 2011
How Do I Set My
1:- Select Clock Adjustment mode
Press the top or bottom side of the Control knob. Select the "ClK ADJ"/ "ClCK" display.
2:- Enter Clock Adjust mode. Press the centre of the Control knob for at least 1 second.
The clock display blinks.
3:- Adjust the hours. Press the top or bottom side of the Control knob.
Adjust the minutes Press the right or left side of the Control knob.
4:- Exit Clock adjustment mode, Press the [B.BOOST] button.
Now whats the time, Gotta get my tea.
Regards, Dave
3/20/2011 11:02:56 PM •
Kenwood...
Answered
on Mar 20, 2011
I have kenwood car
See page 11: http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
3/14/2011 8:13:58 PM •
Kenwood...
Answered
on Mar 14, 2011
