20 Most Recent
Alpine iDA-X200 Car CD/ MP3 Player Questions & Answers
IPOD is hanging but can't be reset.
i would try reformatting your ipod to factory specs (can be easily done with itunes following the information provided at mac.com)
to reset the ipod, turn it off, then on -- then hold down the 'menu' key while pressing the center 'click' key until you get the apple logo. this just may solve the problem.
My ida x200 says intrrupt
1) Press and hold Func/Setup for more than 2 seconds2) Using the Volume knob go to the sub function called General3) Then go to INT MUTE4) Then set it to OFFThis will sort your problem out hope this helps
Where can i find the
support.alpine-usa.com/products/documents/OM_IDA-X200.PDF -
it is in manual above.
My alpine ida x200 keeps skipping during songs
All you can really do is use a CD Player cleaner *one that uses fluid* run it thru a couple times and try a disc again. Clean your CD's with liquid car polish an a microfibre towel, it works wonders for new and old CD's. If it still skips, It needs to be pulled for repair. They just replace the transport, usually runs between 100-150 depending on the service center. Hope this helps.
DC error message
tonite while driving on a bumpy road i had the dc error right after a big bump.
according to user manual,
one of your speakers connector got lose and is touching the metal body of the car giving a shortcut
-> check your speakers wiring
I need a manual
if i were you id go to alpine.com or go to google and try to find the phone number for alpine
Amp turns on with the tuner setting and plays, when i switch to ubs mode the amp shuts off
Hello daweeksy115x,
You did not specify your install specifics, but the trouble is probably the head unit "remote turn-on" lead. Some head units will have both a power antenna and a remote lead. If you inadvertently wired the amp turn-on to the power antenna lead, it can cause the problem you described.
If you head unit does not have a dedicated remote lead, the best solution is to wire the amp turn-on terminal to a switched accessory 12V source.
Hope this helps.
Sat radio not working
It's a Bad SIRIUS Tuner. there have been lots. If it's in warranty, have it replaced. if not, you can still find that unit for around $50 from Crutchfield etc. Hope this helps.
