20 Most Recent
Audiovox UV8020 Questions & Answers
Phase linear uv8020
you probably have constant power running the radio. do you have constant and ignition wires from the radio hooked up or did you twist the yellow and red wires together? if this installation was done correctly than you the unit should power off when you turn the ignition off.
Phase linear screen radio won't shut off how to fix it?
Well first of all you can try to reset your audiovox - To correct a system halt or other illegal operation, use the tip of a pen to press the reset button (9) located on the front bottom-left corner of the unit. After a system reset, the unit restores all factory default settings.
Good Luck!!
Thanks
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
