20 Most Recent Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE Questions & Answers
Battery has died how do
quiet easy, but anyhow, now warrenty whatsoever!you need:a) one hex screwdirver size 5mmb) 1 phillips screwdriver size 2c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)e) some gluef) depending on your expertnes, 20 to 40 minutes time.... yes thats all.here we goDISASSEMBLY1. lay the unit on to back2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)3. remove the three edge protectors4. unscrew the front panel (8 screws, phillips)5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough6. lift the grill without bending and remove it7. unscrew the main speaker (4 screws, phillips)8. carefully lift up the main speaker9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew10. unplig 2 battery leads11. lift out te batteryASSEMBLY1. glue some of the foam rubber arround the new battery, take tie old battery as sample.2. slide in the battery3. connect the leads to the battery, the red goese to te red marked pole. Importand4. Mount the battery holder 4 screws phillips5. slied in the speaker, mout it wit 4 screws, phillips6. mount the grill without bending7. siled the frontpanel back into position and screw ist (8 screws, phillips)8. bring the edge protectors back into position9. Mount the edge plates (3 hex screws each)10. put it back on the weels and load your battery. Testrun.11. have a beer for me and enyou your music.
6/21/2014 11:42:56 AM • Alesis... • Answered on Jun 21, 2014
Were is the outake intake and 10 amp fuse sited .cheers
Same quest I had. So, with flashlight, look inside the 3 prong AC receptacle. It's subtle, but on the lower inner "shelf" of receptacle can pry outward toward you with jewelers or thin standard screw driver. Fuse holder and fuse popped out with a hard pry. Does it look burnt? Mine ohmed out okay, so must be some other problem. 8 sec of charge light when 1st plugged in; then no light. Works plugged in but not unplugged. Idled a year in the garage. My fuse was 750mA 250 (in America, 110V)Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off. -Cheers
9/12/2013 5:40:19 AM • Alesis... • Answered on Sep 12, 2013
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
9/12/2013 5:24:44 AM • Alesis... • Answered on Sep 12, 2013
My Alesis mobile PA system will not charge! What can I do to fix it to where it will charge the battery again?
this adapter for 9VAC adapter replace Alesis SR-16 SR16 drum machine,http://www.powerpayless.com/9vac-adapter-replace-alesis-sr-16-sr16-drum-machine.htmlyou can ask them for your PA system power adapter,
4/12/2013 10:19:28 PM • Alesis... • Answered on Apr 12, 2013
My Alesis Interactive Mobile Amp seems to have a
change the battery, its quiet easy, but anyhow, now warrenty whatsoever! you need: a) one hex screwdirver size 5mm b) 1 phillips screwdriver size 2 c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270 d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it) e) some glue f) depending on your expertnes, 20 to 40 minutes time. ... yes thats all. here we go DISASSEMBLY 1. lay the unit on to back 2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex) 3. remove the three edge protectors 4. unscrew the front panel (8 screws, phillips) 5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough 6. lift the grill without bending and remove it 7. unscrew the main speaker (4 screws, phillips) 8. carefully lift up the main speaker 9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew 10. unplig 2 battery leads 11. lift out te battery ASSEMBLY 1. glue some of the foam rubber arround the new battery, take tie old battery as sample. 2. slide in the battery 3. connect the leads to the battery, the red goese to te red marked pole. Importand 4. Mount the battery holder 4 screws phillips 5. slied in the speaker, mout it wit 4 screws, phillips 6. mount the grill without bending 7. siled the frontpanel back into position and screw ist (8 screws, phillips) 8. bring the edge protectors back into position 9. Mount the edge plates (3 hex screws each) 10. put it back on the weels and load your battery. Testrun. 11. have a beer for me and enyou your music.
11/7/2011 9:37:34 PM • Alesis... • Answered on Nov 07, 2011
0answers
0answers
0answers
I have an alesis transactive
Generally a blown fuse is an indication that something is wrong and needs to be fixed.
If it is happening while the unit is in use, it may indicate power leakage to earth, which could be a safety hazard.
Or it could be drawing too much current because of a circuit fault.
If it happens when the unit is first switched on it could be be because of the initial power surge.
All three conditions could be contributing to some extent.
It should probably be checked out by an electronics technician.
If it only ever blows the fuse on switch on, fitting a slow blow fuse could keep it in service, and may appear to solve the problem, but i would still consider having it checked out and a component fitted to limit the initial current surge, as was fitted in most cathode ray tube computer monitors.
1/29/2011 2:44:37 PM • Alesis... • Answered on Jan 29, 2011
2answers
My Alesis transactive mobile PA
Surprisingly, there is a little compartment just in the outtlet intake in the AMP, and the 10amp fuse was burned. I replace the fuse for a 10amp new one and everything work great. It charge. The little green light of charging, turns on.
1/3/2011 9:59:27 PM • Alesis... • Answered on Jan 03, 2011
3answers
Hey Again, well My transactive
The volume button for the phono can only go as loud as the master volume is set to. In other words the master volume is like a master control that lets nothing go any higher than it, the master, is set to. Because an ipod has very little volume out it needs the master switch to be set pretty high. You should then be able to control the volume with the phono control. Also set the volume on your ipod to it's maximum setting as this will provide a better input signal. However since the ipod is designed to drive earplugs it has very little power out and will never be great on a phono input. It's not a problem with your amp. I find the exact same thing with my 100 watt amp.
9/9/2010 10:41:20 AM • Alesis... • Answered on Sep 09, 2010
Hey currently my transactive has
Hi.
  • IMPORTANT: Ensure that battery is fully charged.
  • Try disconnecting power for ten minutes (unplug power cord) , also remove battery.
  • After connecting back, connect an audio source, but ensure that volume of input sources is zero and devices are off, or you risk blowing the final amp section.
  • Switch everything on in the following order:
  1. Audio input sources (i.e. microphones, instruments, CD/MP3 Players)
  2. Transactive Mobile
  3. last, any amplifiers
  • Disconnect in reverse order.
  • Check connection cables, a shorted coax may cause the same problem.
If that does not help, then the unit is probably faulty, in that case you will need to call support number listed in user documentation.
Here a manual:Quickstart Manual - Rev C
9/3/2010 1:50:57 PM • Alesis... • Answered on Sep 03, 2010
Alesis Strike Pro SE Electronic Drum Kit. Buzzing when powered on.
Bad grounds or connections in the headphones. Try with another set. Or if it is new, something damaged in transit like a loose board.
9/13/2023 5:55:04 PM • Alesis Audio... • Answered on Sep 13, 2023
I have a pair of Alesis M1 Active 520 monitors. One of the has failed.
Bad caps on the power supply
9/19/2019 8:53:07 PM • Alesis Audio... • Answered on Sep 19, 2019
Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE  Logo
20 questions posted
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Alesis Audio Players & Recorders
Most Popular Question
outake intake 10 amp fuse sited cheers
  • Audio Players & Recorders
