20 Most Recent
Harman Multimedia JBL RADIAL MICRO BLACK PERSpeaker System FORMANCE LOUDSPKR DOCK FOR IPOD Questions & Answers
Harman kardon avr 4550
There is no battery to fix this issue. There is a Back Up capacitor that serves this function. Nor a DIY repair. If you require more assistance, or would like to inquire about repairing your HK, please visit my website at audioserviceclinic.com and contact me there.
12/19/2014 2:05:52 AM •
Harman...
Answered
on Dec 19, 2014
With Soundsticks II I lost
Yes, either the internal contacts to the speaker wires are broken or (most likely) the amplifier circuit has failed and you will have to replace it.
It's a complex job that only an experienced repairman should do.
9/9/2011 5:15:55 PM •
Harman...
Answered
on Sep 09, 2011
HK AVR 445 stuck in standby. Power won't stay on.
you have a blown capacitor in your receiver it controls you constant flow of electricity to keep the unit on you cant fix it without the required part so you should take it to the shop
5/15/2011 1:47:36 PM •
Harman...
Answered
on May 15, 2011
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
