20 Most Recent Philips GoGear SA3245/37 Digital Media Player Questions & Answers
Hi, How to Download Music to the Philips GoGear
The Philips GoGear Micro Jukebox is a portable MP3 player that plays MP3 files and WMA files and also displays photos. Download music, copy it to the GoGear player and enjoy your tunes everywhere you go.
Things You'll Need:
* Philips GoGear and USB cable
* Internet connection
* Online music download service
* Secure method of making online payments
* Windows Media Player software
Download music in MP3 or WMA formats. You can buy songs from many online sources. If you choose to buy from iTunes, be aware that you will need to convert them from the native iTunes format to MP3 files. The iTunes software will do this for you.
Import the songs to your Windows Media Player Library if they are not already there. Windows Media Player can be set to check for new files in certain folders each time it launches, so this might happen automatically.
Connect the Philips GoGear device to your computer with the USB cable and click on the "Sync" tab in Windows Media Player. Drag songs you want to copy to the "Sync list" on the right-hand side of the Windows Media Player window.
Click on the "Start Sync" button at the bottom of the list pane when you have all of the songs on the list. You should be able to check at the top of the list pane to see how much space is available on your MP3 player in order to make sure you have enough room.
Wait while the files transfer and then disconnect the player from your computer. You may have to click on "Safely Remove Hardware" in your system tray (usually on the bottom right corner of the screen) depending on your computer.
Have a nice day..
Philips GoGear... | Answered on Jan 05, 2019
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Philips GoGear... | Answered on Jun 04, 2015
You have to make sure that your audio books are in an mp3 or wma format. If they aren't - you will have to convert them which is a fairly simple process.
Philips GoGear... | Answered on Jan 15, 2015
system files might have been deleted
Philips GoGear... | Answered on Sep 21, 2013
Hi! When you repaired your mp3 player you formatted it with ntfs file system but your player needs fat32 file system. Don't be upset just plug in your mp3 player again with your PC and reformat it by changing the file system to FAT 32. Hope this helps.
Philips GoGear... | Answered on Apr 04, 2013
Try formatting it using FAT32 or NTFS file system. I formatted my SA2840 and changed the file system from FAT32 to NTFS (what was I thinking!) and the ending of the story was pretty much the same.
Please check your battery for wear down, and replace it if needed.
Philips GoGear... | Answered on Feb 01, 2013
You may download the user manual and more from here.
Philips GoGear... | Answered on Jul 29, 2012
tienes que convertilos en swv formato y necsitas el convertidor que vino con el mp3 player es facil.
Philips GoGear... | Answered on Mar 08, 2012
Hola martin diaza,
Por mas informacion, visita http://ow.ly/5PS6c.
Transferir el video del DVD al reproductor mediante el software Media Converter:
IMPORTANTE: La mayoría de DVD comerciales están protegidos por derechos de autor para evitar que se puedan convertir y transferir.
Para transferir vídeos al reproductor desde un DVD, siga el siguiente procedimiento:
1. Inserte el DVD en la unidad de DVD y reproduzca el vídeo en el ordenador para comprobar si se puede reproducir.
2. Inicie el programa Media Converter for Philips.
(Ubicación: Inicio --> Todos los programas --> Media Converter for Philips)
3. Haga clic en el botón Add DVD (Añadir DVD) de Media Converter.
4. Haga clic en el botón Browse (Examinar) y seleccione en la unidad de DVD de la lista el archivo que desee transferir.
5. Seleccione Main Movie (Película principal) en Media Converter y haga clic en OK (Aceptar).
6. Haga clic en START (Iniciar).
7. El vídeo convertido se guardará en el ordenador. Ahora podrá transferirlo al reproductor mediante Windows Media Player.
Para obtener más información sobre cómo transferir los archivos mediante Windows Media Player, visite:
www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/mp11/sync.aspx
IMPORTANTE: En función de la potencia de procesamiento de su ordenador, la transferencia o conversión a un DVD puede durar varias horas.
Philips GoGear... | Answered on Jul 28, 2011
Try searching the Internet using Google for this model player. You will get a price comparison from the various suppliers.
Philips GoGear... | Answered on Jun 29, 2011
You need to install the driver.
http://www.driversdown.com/drivers/Philips-SA3285-37-MP3-Player-Firmware-004.001.005_88521.shtml
Philips GoGear... | Answered on Jun 13, 2011
Philips GoGear SA3245/37  Digital Media Player Logo
126 questions posted
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
GOGEAR Philips
  • GOGEAR Philips
Most Popular Question
dont no
  • Audio Players & Recorders
