20 Most Recent
Tech Solution TS-900 Calculator Questions & Answers
On/off button doesnt turn on
normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Can't get numbers to display
Make sure there is not a key stuck in the depressed state. If so try to pull it back up and you should be set. If the machine had a liquid spill this could cause that type of error too. In which case the machine is junk.
On/off button does not work
The ac key is you power on key. As far as not being able to input any numbers, make sure there is not a key that is stuck down or depressed. if so try to lift is up and you should be ok. Unless there was a liquid spill. In that case, cheaper to buy a new one.
The ability to think logically and creatively
Techs should be able to apply a consistent, logical methodology to the resolution of computer problems. This means that even when confronted with new situation, the tech will stand a good chance of being able to resolve the problem, or at least isolate the problem area. To back up their logical thinking, techs also must be able tomake creative leaps in reasoning when the application of logic fails to produce a satisfactory resolution
