20 Most Recent
Sharp PG-F320W Projector Questions & Answers
Hooking up projector to laptop with only HDMI port
The PG-F320W has a DVI-I port between the VGA/Component input and the VGA output. You will need an HDMI to DVI cable or a HDMI to DVI adapter and either an HDMI or a DVI cable. If you use the audio input of the projector, you will also need the audio cable between the computer and the projector. (Make sure to disable the HDMI as the audio playback device. In Windows, go to the Hardware and Sound Control Panel. Then go down to Sound and Manage Audio Devices. Click on the Playback tab and check your output device. Click on Start for Windows 7 and earlier, Windows Key + X for Windows 8. Then select Control Panel.)
Monoprice.com has good prices for most cables. The HDMI to DVI cables are here:
http://www.monoprice.com/Category?c_id=102&cp_id=10231 .
The manual for the PG-F320W is available here:
http://www.sharp-world.com/products/data_projector/pgf320w/pdf/PGF320W_ex1_en.pdf . See page 21 for the DVI cable connection information. See page 61 for video resolutions that the projector can handle.
I hope this helps.
Getting switched off with Temp
hi,
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do
one thing, Remove the fan from the projector. In the fan there will be a
specification sticker. Remove the sicker. now you can see a hole in the
center. its the bearing part of the fan. put one drop of oil in it. u
can use any type of lubricating oil. rotate the fan leafs with finger
for some time. after that re-stick the spec sticker. insert the fan in
the projector. power ON the projector and watch.
ok
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
My fridge won't stop beeping though door is closed
Posibllities to eliminate: 1) bad door seal 2) unbalanced fridge on floor 3) buildup of ice in fridge (defrost) 4) faulty door alarm.
Check temp of fridge. Adjust up or down depending on whether too hot or too cold. Check for blocked air flow or too many items in freezer. But if the exterior is much warmer than usual, you may be looking for a repairman. The main circuit board might be blown
Try a reset by unplugging it for 5 minutes, then plugging it back in. If a minor problem, this may stop the beeping.
Can I order a sensor for my sharp spc908
Maybe worth a look through this catalogue but I doubt spares are available;
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjizJ7-k92DAxWzQkEAHUqwDmQ4ChAWegQIBxAB&url=https%3A%2F%2Fwww.specialized.net%2Fmedia%2Fwysiwyg%2FSpecialized%2Fetc%2FSpring-2023-catalog.pdf&usg=AOvVaw2Z06h4GZtS13wC9OK0rLZl&opi=89978449
