20 Most Recent
HandHeld Entertainment CAD Microphones C195 Professional Microphone Questions & Answers
Cordless mic not working
How old is it? The problem with older electronic products is that capacitors suffer what is commonly called "ESR failure." ESR stands for equivalent series resistance. Basically, they simply dry out over time, or leak. New capacitors usually are very INexpensive (a few cents apiece), but most people know next to nothing about them, nor how to troubleshoot them in-circuit. On the other hand, some of us do know how, but labor is expensive. The best solution, is to simply replace ALL the capacitors in such units, which will usually cost less than $5.00 for the whole lot, and either replace them yourself, or have a friend or hobbyist replace them for you. But soldering technique is important! Soldering is not for beginners, nor for wimps!
5/12/2017 9:38:03 PM •
HandHeld...
Answered
on May 12, 2017
ModelGC821
Hello :
Reset your media player first ! Then update the software of your media player .
good luck .
rate please !
3/20/2010 7:25:02 AM •
HandHeld...
Answered
on Mar 20, 2010
I just brought a coby touchscreen and all it will
No - you do not need an sd card to watch movies and listen to music. This device has built-in memory that you can load using your computer.
Make sure you have content on is that is compatible with it your device and that it was installed using the program that it needs.
If your device only says "please wait" and doesn't let you do anything or access other menus, it is likely that it is defective and needs replaced.
Hope this helps!
Please rate my solution!
1/7/2010 5:57:45 AM •
HandHeld...
Answered
on Jan 07, 2010
Music from computor to phone
Could be you have bought a microSDHC. I think these mobile only support microSD. To find if the card is being recognised by the phone, go to the settings menu and look for a "memory" menu. This will tell you how much memory the phone has found, if there is only the 10MB internal then the card is the wrong type.
12/14/2009 8:39:56 AM •
HandHeld...
Answered
on Dec 14, 2009
HOW DO I TURN IT ON/OFF?
You didn't list a brand or type, but for the most part, modern MP3 players don't have a "power switch" per-say. Most just go into a low-power, or 'sleep' state, but technically stay "on" all the time. There are still some that can be turned off completely, including some of the ones that 'go to sleep', by using a special key sequence. The method is specific to each model, and I would need to know the brand and model to help out any further.
11/20/2009 6:11:11 AM •
HandHeld...
Answered
on Nov 20, 2009
I can't uninstall rca easy rip
thats not what he means, when you do that, it flashes what should seem like should be the uninstaller then it goes away and does nothing.
10/21/2009 3:45:31 AM •
HandHeld...
Answered
on Oct 21, 2009
Hourglass nd blue screen
unplug it from the comp if you havent already. does it have those sunken reset buttons? check the manual or online if you are not sure. if YES, reset the device and move on to the next step. If NO, you can either remove the battery (if possible) and try it back after a little while, or better, let it run out of charge and remove the battery then. By this time, please reboot the computer to make sure its fresh, to use layman language. Does it use a wall charger or has to charge on the comp? Does it have a regular USB 2.0 slot, cuz then you can use your phone charger or some other wall charger with the regular usb jack (male part). If no wall charger, I guess just re-plug it into the rebooted computer, and see if this helps it any. Sometimes my old Ipod 1st gen nano does this, and does not have a reset button or a way to remove the battery, so i just let the charge run out and the battery die, and when I charge it again, it works just fine. tell me how this works.
5/25/2009 9:06:52 PM •
HandHeld...
Answered
on May 25, 2009
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
