20 Most Recent
Kyocera wild card Cellular Phone Questions & Answers
Unlock phone
I’m having a hard time believing this is your phone dude. Good luck anyway. Try 0000.
How do I block calls on my wildcard phone?
Until now, it has been difficult, if not impossible, to block selected phone numbers from ringing your phone. Various features that are offered by some telephone service providers have provided limited relief, at a cost, but until the introduction of the Caller ID Manager, a total solution was not available.
With the Caller ID Manager, you can easily block phone numbers and anonymous callers without added monthly fees. You can now block phone calls from any number that you choose, including local, long distance, international and cell phone callers. A 'Wildcard' feature is included for those who wish to block calls from entire area codes, prefixes, or number sets. You also have the option to block phone calls during specified hours, either on a one-time or daily basis, using the built-in scheduler.
Factory reset
here is a link for manual will show you how to reset.hope this helps
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-wild-card.pdf
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
My phones screen goes white
WHITS SCREEN DISPLAY.
hi,
there are two kinds of white screen in n70 ,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your N70 im sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to a nokia care center to fix you problem...
i hope ,i will help you ,thanks for trusting fixya...
I for got my security password for my kyocera domino pim# 101831
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
My kyocera cell phone just
The phone is probably shot. You can test whether or not a replacement battery will help by trying to turn it on when it is plugged into a power source, like your charger. If it doesn't turn on, you will need a new phone.
