20 Most Recent
General Electric 28821FE2 Phone Questions & Answers
How do you change the message on my GE 28821FE2-A cordless phone?
1. Make sure the answering system is ON.
. Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“.
. Begin speaking after you hear the beep.
. Release the button when you finish your announcement.
NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing.
Sample Outgoing Announcement
Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks.
NOTE: The maximum recording time for the outgoing announcement is 2 minutes.
Reviewing and Choosing the Announcement
Press and release the announce button to review and select this one as your outgoing announcement.
NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
User manual for GE
You can download and print the instruction manual for GE 28821FE3 in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Thanks for using
FixYa.
How do I retrive my messages from another phone?
I think your messages reside on the base station. You shuld be able to retrieve the messages fropm any handset ...
or
Is your question "How do I get the messages on my home telephone from the office?"
You will have to read the secifics in your owners manual ... If you call 555-1234 from 555-5678 when 555-1234 answers, if you press a special code, you should be able to get your messages.
PLEASE UNDERSTAND - the numbers I put above were for demonstration purposes - dont call those fake numbers and expect to get your messages.
I hope this helps you.
Thanks for using fixya.com
a
GE Cordless Phone #28111EE2 --Caller ID not clear
sounds like your phones have been exposed to moisture / water or something similar because it sounds like the ribbon that connects the display screen to the cpu has bad connections and or corroded connections...also these ribbon lines are very close to each other at the cpu side of the phone so any water/ moisture residue will short out some pins to each other and cause all kinds of weird effects like the one your having....I would suggest to have your phones looked at for water corrosion and if still able to..have the board cleaned with acetone or pcb cleaner and resolderd.....good luck
silvio
The 2nd handset worked only week now it
just got the phone as a gift and it worked for one week and is now searching for the base and displaiyng out of range. Followed all tect instructions and still not working. please help
Why am I not receiving General Mailbox voicemails?
Please make sure that the customer is calling the correct number that you think that they're calling. Then, call this number yourself and leave a message before going to check the message again. If you can't find your message, please call the business' phone company and ask them if there are multiple mailboxes linked to your business phone number. If so, they can provide access to the other mailbox for you.
Thank you.
