20 Most Recent
Uniden DECT2085-3 Trio Cordless Phone Questions & Answers
Uniden DECT2085-4WX: waterproof handset displays "Please Wait"
Hey! I have the SAME exact handset. I HAD the same exact problem except this is what you NEED to do:
On the bottom on the handset, there are two "HOLES".
There's a smaller "rubberized" hole and to the right, a later "Double Layer" hole.
The a ball point pen and GENTLY push into the lager, "double layer" hole.
You will then hear a CLICK or a POP. THIS IS OKAY.
Your phone should now be placed on the charger for at least 25 hours prior to first use.
This procedure will ONLY need to be done ONCE.
This is necessary because the battery pack was factory installed by Uniden, therefore the installed battery is NOT "contacted" to the phone's circuit, yet.
WHEN YOU "CLICK" the SEAL w/ a BALL POINT PEN, you are "CLICKING A METAL CONTACT" inside the phone, which causes the battery to make contact with the phone.
After this, I AM SURE YOU WILL NOT have this problem again! :-)
HOPE THIS HELPS!!
2/1/2010 2:00:45 PM •
Uniden...
Answered
on Feb 01, 2010
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
