20 Most Recent
Garmin nuvi 750 GPS Receiver Questions & Answers
Same problem on Garmin Nuvi 755 model
Check with Garmin to see if there is a way of resetting the electronics to factory defaults. Also check with them to see if they have software for you to do a clean install if necessary
No french laguage
On the Nuvi 7xx series as well as many other nuvi models, voice updates are free and downloadable from garmin.com. Garmin only charges for map upgrades. Maps do not contain voices. I have backups of french text to speech (TTS) voices. I would be happy to give you links to download them to you.
Keeps saying "recalculating"
Hello :
There is a software problem with your GPS . I recommend you to reset it to solve the problem .
To reset your NUVI , please follow one of these procedurs :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented
by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation
message will appear asking to confirm restoring the Nuvi to factory
settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the
touchscreen [ Don't let go
] , and then power on the GPS unit. You should be prompted whether do
you really want to erase all user data, or asked if do you really want
to start up in maintenance mode. Press “Yes” to reset (warning: all data
will be erased and lost, so backup before proceeding) or enter
maintenance mode.
PLEASE DON'T FORGET
TO RATE !
My garmin 760 screen reads "press dot".
Hiya! All you need to do is use a ds pen (or something that is plastic and will fit within the black dot) - our fingers are to big for the calibration. Ive just fixed mine. It should correct its self within 10 dots and away you go again :)
