20 Most Recent
Garmin Nuvi 255 GPS Receiver Questions & Answers
Hello Was hoping to get a video on how to
First, a freezing problem or lock-up during boot-up has nothing to do with the LCD display. If the screens shows a graphic, such as the Garmin logo and without lines or splotches, then the screen is fine. Lock-ups during boot-up are caused by corrupted firmware or maps or a corrupted flash drive. All of which can be resolved without taking the unit apart. The battery has nothing to do with it either. If the unit locks up while connected to the car charger, then the battery is essentially being charged and not powering the unit. I can't see your board but if you pulled the ribbon out of the board, you may have damaged the locking latch that holds the ribbon in place. The locking latch is a thin white or rust-colored strip of plastic on a hinge. That hinge should be up when sliding the flex cable into the connector, then the locking latch is pushed down toward the flex cable until you hear it click. The flex cable should be secured at this point. If you have busted the locking latch off, it is game over for your Nuvi. More info on booting issues can be found here:
http://www.sharc.net/gps_bootup_repair.htm
It says . cant unlock maps.
Follow this below
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
No battery status in the
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
I have 2 Garmin (205W and new 255W). I downloaded
It should unlock automatically.
Try reconnecting your device to computer and going onto the garmin site and get the website to check for updates.
If that fails to work, give garmin a call or send an email to them.
they are normally very quick.
Please dont forget to vote if you liked my answer
thanks
No sattelite reception
There are certain conditions that must be met before you can receive a satellite reception. You can go through your manual to make sure that all the conditions are met.
If all is well and it still doesn't work, comment here and i will give you further instructions on what to do
Free opdates for Garmin nuvi 255
There are no free updates. You can buy the current version OR you can buy the lifetime update package. Go to your retail store or to Garmin.com
Has been charged, but has no power, will not turn
mine did that aswell.checked out n tried solutions on this n other sites with no luck.i eventually just opened it to check the battery(unit 1yr old).batt was fine.when i put it all back together it works fine.assume that disconnecting battery is the mysterious reset button.hope this helps
Battery power was low on my nuvi 255.plugged into
The 2xx series had a batch with bad batteries and they are replacing them even out of warranty , try your serial number on https://my.garmin.com/rma/recallLanding.faces. See if it is eligible for repair, if not the unit is probably pooched.
Hope this helps!
Talking has stopped
First
press the speaker symbol and check that the volume is not down fully or
that the mute box is not ticked. If it is press the mute box to untick
it or increase the volume. Otherwise follow the instructions below.
1.
Press Tools, then press Settings (or Locale on some models), then press Language. You will see a
bar for Voice. Press Voice and select a different voice. If this
doesn't solve the problem it's most likely because the voice file has
become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
and connect your satnav to your computer. Install webupdater and your
satnav will look for updates. After it's finished it will give you an
option to download voices. Click the ones you want and press next. The
voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
My Garmin 255 quit displaying my destination map
This problem is caused by the mini usb plug of the power cord not being fully plugged into the back of the satnav. It's a common problem on 200 series garmin satnavs. Because of the way it's made you think it's fully in but it's not. Push it in further and the problem will be solved.
I don't know how to change the language from
To change the text language:
- Touch Wrench icon on the screen with the Magnifying Glass and Map icon
- Touch the Gears icon
- Touch the down arrow
- Touch the second option from the top
- Touch the middle blue box on right
- Touch the up arrow until Arabic appears
- Touch Arabic
- Touch OK
- Touch Back
The device should be in selected text language.
To change the voice;
- Touch the Tool icon
- Touch Settings
- Touch Language
- Touch Voice
- Touch the Voice Language you would like to use
- Touch 'Ok'
- Touch and hold the Back button to return to the main "Where To" and "View Map" menu
At this time your device should speak in the language you have set in step 5.
If there's not an Arabic voice on your satnav for you to select connect the satnav to your computer. Download the latest version of webupdater from
http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. It will check for updates to the software on your satnav and afterwards it will show you Voices available for download. Select an Arabic one by ticking it. Click next and it will be downloaded. When the download is finished go select the voice on your satnav as described in the previous paragraph.
Garmin Nuvi is plugged into the electrical outlet
If the lighter socket is working ok then it may be the fuse in the charger plug that's gone. It can be replaced by unscrewing the silver ring at the end of the plug and removing the fuse. A replacement fuse should be available from garmin dealers.
