20 Most Recent
Amcor AF 12000E Portable Air Conditioner Questions & Answers
We have had this unit for 1.5 years and it runs
The first thing I would do is check refrigerant levels to make sure that your unit is operating at the proper pressures. I would expect that with you doing maintainece every two weeks that you will find it is low on refrigerant. I hope this helps you. Thank you.
We purchased a Amcor Amcoraire
Hi, this is a 1-ton cooling unit per your numbers. If they just installed it and the line side (120 volts) is good but nothing on the secondary low voltage side, they should have replaced the transformer themselves? If it is a split system, it is normally on all splits to be located in the indoor unit control section. I can't tell you exactly, but look where the 120 volts come into the indoor unit and the high voltage wiring should be connected to it then stepped down to lower voltage. It may have a fuse on the circuit board that they blew when installing it. If you are not familar with electrical, I wouldn't attempt to make these repairs. You can look for a small plug in type fuse to see if it blew, it looks like one on your automobile. I would call this installer out and its there job to do this!! These transformers look different, there not all the same, but will have a black and white wire coming in, and several colored wires coming out for low voltage. It will be in the indoor unit. Keep me posted on what you find or if you need more help. How long ago was the unit installed?
Shastalaker7
