20 Most Recent
Heat Controller PE121A Air Conditioner Questions & Answers
Air conditioner not working.
Assuming this is a dual unit heats and cools. You may have a sticking transfer valve or a defective compressor. The trf valve simply switches the cool to the heat. Suggest you contact a qualified ac technican.
Heat controller model B-dmc24sb-1 leaking water in to room
This is normally due to the drain hosing being blocked. Find where the hose drains the water to, which is likely to be outside the house or into the drains, and check that the end is not blocked. If this is OK you will need to follow the hose back to the unit and find where the blockage is.
