20 Most Recent
HP Pavilion m8120n PC Desktop Questions & Answers
System fan error
If you have replaced the fan and you are still getting a "Fan Error" then you have replaced the wrong fan. The system fan is not fitted to the top of the processor, it is usually fitted to the case.
Getting 2 short beeps and 1 long beep – black
Your computer has memory problems. First checkvideo. If video is working, you'll see an error message. If not, you have aparity error in your first 64K of memory. First check your SIMM's. Reseat themand reboot. If this doesn't do it, the memory chips may be bad. You can try switchingthe first and second banks memory chips. First banks are the memory banks thatyour CPU finds its first 64K of base memory in. You'll need to consult yourmanual to see which bank is first. If all your memory tests good, you probablyneed to buy another motherboard.
Clean the ram and the ram slot .then fit it again.
http://www.ehow.com/how_895_install-ram.html Hope it will help you.
Want to upgrade memory but how do i access the
Open the access panelUse the following steps to open the case:
WARNING:
The edges of metal panels can cut skin. Be careful not to
slide skin along any interior metal edge of the computer.
CAUTION:
This product contains components that can be damaged by
electrostatic discharge (ESD). To reduce the chance of ESD damage, work
over a noncarpeted floor, use a static dissipative work surface (such as
a conductive foam pad), and wear an ESD wrist strap connected to a
grounded surface.
NOTE:
If you need product model specific
graphics and instructions for opening the PC, search for a support
article that specifically pertains to your computer. In the Search field
(or Questions or keywords field) at the top of this page, type your
computer model number, a space, and the words "opening the case."
- Turn off the computer and unplug
all cables, except for power, and write down each cable location.
- Unplug the power cable and press
the Power
button.
- If
possible, move the computer to a clear, flat, stable work surface over
an uncarpeted floor.
- Remove
the panel retaining screws.
Figure 2: Screw locations
(your model might look different)
- Slide off the panel to expose the inside of the
computer.
Figure 3: Panel removal (your model
- If opening the case is difficult, search for a
support article that specifically pertains to your computer. In the
Search field (or Questions or keywords field) at the top of this page,
type your computer model number
the case
Computer was moved and now I have no sound
Firstly check whether the sound driver is installed or not. Secondly, make sure that you haven't turned on the Mute (You will see red X mark on the sound icon). Thirdly, Check the output connector (Audio Jack). Forth, try your speaker to another system to see if it's working or not. If you follow all these steps and you still get no sound, then the problem is with the sound card. But in your case, I hope these will definitely fix your problem. Good luck
Wireless Keyboard stopped working
Try unplugging the receiver unti for 5 seconds, then replug it in. If this does not work you should try reinstalling the wireless system drivers. Hope this helps.
Replacing power supply HP M8120N
Here is the link for the upgrade and service guide.This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
- the wifi card is missing, as was super common 10+ years ago.
- someone put in the wrong card, not from HP list
- HP blacklists (bios blocks) none HP cards (wifi)
- the card needs a driver to work if not it is dead or 1/2 dead.
- the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
- The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did
google bios update bricked my PC and cry.
why are you here and not at HP.com
only they can recover bios.
they changed the rules now 10 time.
so only they know this, and are pain to deal with.
UEFI is the enemy here, new rule and regressive as can be.
in fact all new PCs can not be regressed, and some old now
they even delete the 20 version of bios there, to force that.
not saying they did that to your PC, but keep that in your head on all HP PC.
the last bios upgrade stated, no going back.
the Cntrl_+B might work , the flashback bios trick\
in your manual if you read it.
