20 Most Recent
Yamaha YHT-390 Theater System Questions & Answers
Hi I have a Yamaha yht 292 surround sound system
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
I'm not getting YHT 391 surround sound during TV
I havent received my system yet,but while reading the manul it says the hdmi cable only transmits the picture(i know i know hdmi supposes to transfer both)you suppose to hook up an dital or coaxile cable for the sound
What is the correct wiring connection using hdmi
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Yamaha YHT-390 Home Theater System
Here is a link to your receiver, at the bottom there should be a download link, The receiver you listed isn't there but maybe the few that are there can help. Hope this will be some help!
http://www.yamaha.com/yec/products/productdetail.html?CNTID=567702&CTID=5000800&RLTID=1505&DETYP=RELATION
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
