20 Most Recent
Viking DTBB363 Bottom Freezer Refrigerator Questions & Answers
Fan constantly running on top of viking refrigerator , vcbb363 bottm mount freezer
It sounds like there may be an issue with the fan or the control board in your Viking refrigerator. The constant running of the fan, even when the compressor is not running, is not normal. The fact that different repair technicians have given different diagnosis and the issue persist even after replacing the compressor fan motor, suggest that it may be a problem with the control board, which manages the refrigeration system, including the fan. It could also be a problem with the thermostat, or the system's settings. Since the fridge and freezer seem to be at normal temperatures, it may not be a problem with the cooling system. It's best to contact Viking customer service for further assistance and see if they can provide any additional information or troubleshooting steps. If the issue persist, it's best to ask for a senior technician or supervisor to take a look at it and provide a resolution.
9/29/2023 7:15:33 PM •
Viking...
Answered
on Sep 29, 2023
How to replace ice maker signal arm
- Safety First: Before you begin, unplug the refrigerator from the electrical outlet to ensure your safety.
- Locate the Ice Maker: The ice maker is typically located in the freezer compartment of your refrigerator. It's usually mounted to the side or top of the freezer.
- Access the Ice Maker:
- In some refrigerator models, you may need to remove the freezer's interior shelves or baskets to access the ice maker.
- Others may have a cover or panel that needs to be removed to access the ice maker assembly.
- Identify the Signal Arm: The signal arm is a slender, plastic or metal arm that is connected to the ice maker assembly. It extends over the ice bin or tray.
- Remove the Old Signal Arm:
- If the signal arm is attached with a screw, use a screwdriver to remove it.
- If the signal arm is connected with a clip or latch, gently detach it by carefully pulling it off the pivot point. Some signal arms may have a small locking tab that needs to be released first.
9/6/2023 8:38:58 PM •
Viking...
Answered
on Sep 06, 2023
Viking Built-In Refrigerator Not Sealing Intermittently
Check the door gasket for torn or broken attachment tabs. Gently go all the way around the door gasket, wiggling it to see if any part of it pulls out of place. If you find a build-up of dirt, mold, etc,. clean that off. If there is mold present, clean it with a borax solution. Also check the door frame on the refrigerator shell where the gasket is supposed to seal. If you see one area that is particularly dirty or signs of frequent condensation, double check the corresponding part of the gasket for defects.
I'm hypothesizing that a broken section of the gasket sometimes rolls or moves sideways, thus preventing proper sealing.
I have also had problems with the door staying closed if something in the freezer or refrigerator sticks out just enough to put outward pressure on the door (or a similar protrusion of items in the door racks). In that case, re-arrangement of the freezer contents should fix it.
8/16/2023 5:27:26 PM •
Viking...
Answered
on Aug 16, 2023
Do you have to use Viking Wine fridge parts to fix a Viking Wine cooler?
I wouldn't pay upfront because the repairman doesn't know what the main problem is. You can first reach out to the product's manufacturer for recommended repair vendors. But if this fails, then you can call your nearest Lowe's or Home Depot for parts and repair assistance.
Thank you.
12/24/2022 9:39:14 AM •
Viking...
Answered
on Dec 24, 2022
Can I replace a Viking DFBB363L low voltage control board myself?
seems to me he is a crook, (aka a scalper)
why not buy one cheap and put it in.
the online manual free shows the parts inside
many Refers only have timer clock for defrost timer job.
as you can see the year matters for this board. nov 2003 cut off.
see this gem
http://allvikingparts.com/v/vspfiles/downloadables/DFBB363.pdf
now shop by the exact part numbers.
or call maker and ask for qualified repair shop>? in what country I do not know, not told. and parts are best obtained close by,
no down time.
my guess wild he means part ID #5"?
G50911837LOW VOLT / HIGH VOLT BOARD KIT (BEFORE 11/17/03)
(BEFORE 11/17/03)
G50911826LOW VOLTAGE BOARD KIT (AFTER 11/17/03)
(AFTER 11/17/03)
5G50911826LOW VOLTAGE BOARD KIT (AFTER 11/17/03)
PE970463POWER CONTROL BOARD
(AFTER 11/17/03)
7/5/2022 9:31:54 PM •
Viking...
Answered
on Jul 05, 2022
My Viking Icemaker is leaking.
Eva, it is faulty, call for service. You can't fix these things yourself. Your water inlet valve is stuck open.
6/19/2022 4:16:30 AM •
Viking...
Answered
on Jun 19, 2022
