20 Most Recent Viking DTWL4848 Kitchen Hood Questions & Answers
2answers
Viking 10 inch hood lights out
It is more than likely the dimmer switch has gone bad and needs to be replaced
10/28/2011 8:37:50 PM • Viking DTWL4848... • Answered on Oct 28, 2011
6answers
How to take out the circuit board on a Viking DTWL 4848
any fault with this unit should only be attend to by qualify tecnician
2/2/2009 12:52:05 PM • Viking DTWL4848... • Answered on Feb 02, 2009
How do I replace the glass top that is broken on a Viking VESC530-4B electric range?
Service Manual https://www.manualslib.com/manual/1048953/Viking-Vdsc530.html?page=42#manual The parts schematic shows 6 screws UNDER the glass holding the frame down. https://allvikingparts.com/v/vspfiles/downloadables/VESC530.pdf My guess would be that you remove the back edge of the trim and slide the glass out. ..
1/26/2024 4:14:11 AM • Viking Kitchen... • Answered on Jan 26, 2024
I need to replace the elements in my old Eaton Viking stove from the 70's or 80's but I can't find the specs.
I have an early 70s GE stove that looks like that era Vikings. They are pretty much the same wattage, if I remember oven is 2,500 watts. You buy them by shape. You need the model number, it will be at the rear on a stamped metal tag. I just take the old one to Canadian Tire and pick them off the shelf for about $36.00 CDN. Stove TOP, Stove Oven? Viking sell parts. https://www.allvikingparts.com/PJ010004_BAKE_ELEMENT_p/pj010004.htm Or pick by the images. The stove top elements are just in two sizes. Given the model number and the element you need, I bet I could find them. https://www.google.com/search?q=eaton+viking+stove+elements&sca_esv=594661664&rlz=1C1QJDB_enCA643CA644&tbm=isch&sxsrf=AM9HkKlr1Ku7omqszJ4KH0QuOR20gYnwYQ:1703985066791&source=lnms&sa=X&ved=2ahUKEwiH7O6Ev7iDAxUEEVkFHaxMCs8Q_AUoAnoECAEQBA&biw=1920&bih=919&dpr=1 ..
12/31/2023 1:20:54 AM • Viking Kitchen... • Answered on Dec 31, 2023
Viking VESO 530SS Oven. Self clean light flashing.
Question edited for clarity. The whole idea of Self Clean feature is to keep the makers into steady sales of spare parts. The components can only tolerate those temperatures for a number of cycles before elements, door locks and control boards start failing. Consumers don't realize the heat involved! between 800°F and 900°F Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (except they aren't) Either the door lock has failed or the control board has failed. https://www.justanswer.com/appliance/6r72n-own-viking-dual-fuel-vdsc530-range-oven-will-not.html
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
12/31/2023 1:08:37 AM • Viking Kitchen... • Answered on Dec 31, 2023
I have a Viking gas stove. The burners work but the oven and broiler do not. No gas flow or sound of ignition from either
It sounds like the pilot light has gone out. The thermocouple might have failed. It is a gas appliance so you will need a gas certified technician. Google Viking (model) manual ..
12/5/2023 4:47:24 AM • Viking Kitchen... • Answered on Dec 05, 2023
Replacement control switch #031733-000 wiring diagram
Are you sure it's a good idea to do everything yourself? I don't think you should do that because you can easily connect the wires the wrong way, and I don't even want to think what can happen in that case.
6/1/2023 7:23:58 AM • Viking Kitchen... • Answered on Jun 01, 2023
Trying to date a Viking range/oven.
2/23/2023 4:19:53 PM • Viking Kitchen... • Answered on Feb 23, 2023
How to turn-off the self cleaning on an Eaton viking 1997 range
To turn off the self-cleaning cycle on your Eaton Viking 1997 range, follow these steps:
  1. Press the "Off/Clear" button to stop the self-cleaning cycle.
  2. Wait for the oven to cool down completely. The self-cleaning cycle can take several hours, so it's best to wait at least a few hours before attempting to turn it off.
  3. Open the oven door and remove the racks.
  4. Use a damp cloth to wipe away any remaining debris or ash from the oven walls and bottom.
  5. Close the oven door and press the "Off/Clear" button again to reset the oven.
  6. Your Eaton Viking range should now be back to normal and ready for use.
2/23/2023 11:20:07 AM • Viking Kitchen... • Answered on Feb 23, 2023
Viking VGIC306 oven malfunctions occasionally
This sounds like your ignitors are failing. I would replace or try cleaning ignitors.
2/3/2023 9:38:27 PM • Viking Kitchen... • Answered on Feb 03, 2023
Viking gas oven won't shut off
It sounds like you are experiencing an issue with your Viking VGSC486-6Q gas oven where the gas continues to flow and the oven continues to heat even after the desired temperature has been reached. This can be a dangerous issue, as it can cause the oven to overheat and potentially start a fire. Here are a few steps you can try to troubleshoot the issue:
  1. Check the oven sensor: The oven sensor is responsible for measuring the temperature inside the oven and sending a signal to the control board to adjust the gas flow and heat as needed. If the sensor is not functioning properly, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the sensor with a dry cloth and making sure it is securely connected to the control board.
  2. Check the control board: The control board is responsible for receiving the signal from the oven sensor and adjusting the gas flow and heat accordingly. If the control board is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try resetting the control board by unplugging the oven and plugging it back in, or you may need to replace the control board.
  3. Check the gas valve: The gas valve is responsible for regulating the flow of gas to the oven. If the gas valve is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the gas valve and making sure it is securely connected, or you may need to replace the gas valve.
If none of these steps help resolve the issue, it may be necessary to have the oven repaired by a professional. It is important to address this issue as soon as possible, as it can be dangerous to use an oven that continues to heat even after the desired temperature has been reached.
12/31/2022 10:03:36 AM • Viking Kitchen... • Answered on Dec 31, 2022
2answers
Viking 4 burner stove. Burner caps are clean and properly placed. The two front burners are very low and will not adjust with the knob. I tried the adjustment screw to no avail. what next
Hi, you might need to get the 2 burners/knobs updated. You can schedule a diagnosis with Home Depot over the phone in order to get the burners and the knobs checked. Prior to that, try opening a window to let in more oxygen while running the 1 o 2 of the troubled burners. Thank you.
11/17/2022 3:25:37 AM • Viking Kitchen... • Answered on Nov 17, 2022
OVEN LIghT KEEPS BLINKING AND WILL NOT HEAT UP.
Hi, Please power cycle your over from your fusebox if possible. If this is not possible, then please take not of any pattern with the blinking of the oven lights. You can check if the oven door is cracked open or there is excess dirt within the oven. Before setting an appointment to check your gas connection, I would recommend searching for mention of the blinking pattern within the troubleshooting section of the oven's manual. Thank you.
11/6/2022 2:06:15 AM • Viking Kitchen... • Answered on Nov 06, 2022
2answers
I have a Viking pro model oven VGIC3064BSS that doesn't light fully
Viking Gas Range Burners Won't Light? Here's What To Do... We'll discuss how to properly check the power sources and igniter when your Viking gas range burners won't light. We'll also provide a step-by-step guide illustrating how to clean Viking range burners with the right methods and materials.
Check For Power And Loose Connections
Are your Viking stove burners not igniting on demand? This may be more of a power issue and not a range malfunction. Even though you have a gas range, electricity is still required to ignite the burner. Here's how to check your stove's electrical sources to make sure they're functioning properly:
  • Make sure the stove is correctly plugged into a functioning outlet.
  • Check the stove's circuit breaker or fuse in your home's circuit breaker or fuse box. Reposition a tripped breaker or replace a blown fuse.
  • Refrain from using an extension cord to power your range. Most cords can't safely transmit the electricity required to power the stove.
How To Clean Viking Range Burners
Despite our best efforts, cooking spills and accidents can leave range burners compromised. Liquids, grease, and grime that go unnoticed during a hasty post-dinner cleaning can impair range components, resulting in burners that won't light. This step-by-step guide provides Viking range cleaning tips that clean your burners and other stove components safely and effectively:
Grates:
Remove the grates and soak them in a sink of hot, soapy water for 15-20 minutes. For stubborn stains, add ammonia to the soaking liquid or scrub with Soft Scrub cleanser. Rinse with hot, soapy water and dry completely before replacing.
Burner Caps:
  1. Remove the caps by lifting straight upward.
  2. Scrub with hot, soapy water and a non-abrasive pad, using Soft Scrub cleanser for tougher stains.
  3. For persistent staining, place burner caps outside on a sheet of newspaper. Spray with Easy-Off Fume Free Max oven cleaner and allow to sit for 1-2 hours.
  4. Rinse with hot, soapy water.
  5. Allow caps to dry completely before replacing.
Burner Heads:
  1. Remove burner heads by lifting gently upward.
  2. Combine Bar Keeper's Friend and water to make a paste.
  3. Apply the paste to the burner head and leave for 30 minutes, resting on a clean towel.
  4. Scrub the paste into the burner head with a non-abrasive pad to remove stains.
  5. Rinse with hot, soapy water.
  6. Allow to dry completely.
10/5/2022 7:07:28 PM • Viking Kitchen... • Answered on Oct 05, 2022
2answers
I have a Viking gas oven and recently while on bake it automatically turns to convection. It has happened twice but I don't use the oven that often.
You have a problem that no one else has encountered. I would use the convection feature all the time as it keeps a much more even heat. Could it be that convection starts when the oven reaches temperature.? A model number would be useful in questions like this to find a manual. https://www.google.com/search?q=Viking+gas+oven+and+recently+while+on+bake+it+automatically+turns+to+convection ..
8/28/2022 9:06:52 AM • Viking Kitchen... • Answered on Aug 28, 2022
2answers
How long Viking oven fan should stay on after it's off
bad temp sensor to turn off fan or control board
4/8/2022 10:40:55 PM • Viking Kitchen... • Answered on Apr 08, 2022
Why is my Viking gas Oven not Heating?
Normally the thermocouple is not working properly. The thermocouple opens the main gas valve once it registers that the pilot is alight and hot.
2/19/2022 10:46:14 PM • Viking Kitchen... • Answered on Feb 19, 2022
Viking DTWL4848 Kitchen Hood Logo
4 questions posted
Top Viking Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Kitchen Ranges
Most Popular Question
viking 10 inch hood lights out
  • Kitchen Ranges
