20 Most Recent
Encore ENHWI-N Router Questions & Answers
Having a problem getting DynDNS to pass through
I did this with a cctv and another dns server and does not really work. So i just change my ip to static and open ports 80 and 443 and 8000 (server) and worked fine without using ddns or free dns. Oh and i use this to check my ports if they are working http://canyouseeme.org/
ENHWI-N Router: i have 7 computers sometimes 1 or two of them have...
If you are connected through wireless, it could be because of low signals in some areas of your place. Stay away from chord-less phones, microwaves, or anything that could interfere with signal of the router. If you're too far from the wireless router, it could also be an issue.
Another issue could be that the DHCP setting is configured in such a way that it only leases 5-6 IPs at a time. You should check the configuration. Also, check the PC if they are receiving an IP if the PCs are configured to get an IP dynamically.
Problem with Encore 802.11n Wireless Router ENHWI-N2
Well a router that supports 802.11n will also support g.
In any case I am under the impression that your DNS settings might be wrong.
A good router to look at are D-Links, I have been using the DIR-655 for my house see: http://www.dlink.com.sg/products/?idproduct=21&idCategory=175
Enjoy
How do I hook up my ENHWI-N router? I took the
ok, WAN goes to your internet connection. LAN goes to the computer to access. If it is the usual default, you might get a DHCP address like 192.168.1.2. In your browser, type http://192.168.1.1 and see if anything comes up.
Router drops connection
Its your bad luck that u purchased this router. Basically Its a very cheap product from china. It got hot & dies very soon. This is major problem with this model. Company suggesting the firmware upgrade but i didn't find a single solution with that. So the best answer is to replace it with another model.
Thanks for contacting Fixya
PLZ GIVE RATING BY CLICK ON YES OR NO.
I have encore enhwi-n router;
You need to clone the MAC Address of the PC that can go online directly to the Smartbro connection. Make sure the connection is correct. Your PC should be connected to port 1 on the router and the ethernet from smartbro to WAN or Internet port.
I have windows 10 and I am using Printshop deluxe 6.0. I worked fine since it was purchased Oct 2022, all of a sudden it won't print my projects and I can no longer save them as JPRG
If PrintShop Deluxe 6.0 is no longer printing your projects and you are unable to save them as JPRG after uninstalling and reinstalling the software, there may be a few other things you can try to fix the problem:
- Check the printer settings: Make sure the printer is properly set up and connected to your device. Check the printer settings to ensure that it is set to the correct printer and that the printer is not experiencing any errors or issues.
- Check for updates: Check for updates for the software and the printer driver. Installing any available updates may fix the issue.
- Check for compatibility issues: Make sure that PrintShop Deluxe 6.0 is compatible with your version of Windows 10. If the software is not compatible, it may cause issues with printing and saving projects.
- Repair or reinstall the software: Try repairing or reinstalling the software to see if it fixes the issue. Make sure to follow the instructions provided by the manufacturer or technical support team to properly uninstall and reinstall the software.
If these steps do not help, you may need to contact Encore or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the software for any troubleshooting tips or recommendations.
I have the 112 twelve
Please clean the discs in + manner. Meaning, take a soft cloth and rub it un-down and sideways and not in circular manner we usually do. Also clean the read/write head of the CD drive. It is the shiny blue dot. try running the discs in your friends computer to make sure they are fine and not damaged.
