20 Most Recent
Viking VMOS200 Microwave Oven Questions & Answers
Viking vmos200 sparking
If there is spark please do not switch on
unless you have confirmed the fault. It is possible that the Magnetron is
leaking and sparking to the ground. As you have mentioned it was stored, it is
quite possible that insect can get into the oven and create soft spots. When
you switch on these will create a short and make the voltage jump and in the
long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if
so wipe clean and dry, check the magnetron and area clean and use an jet air to
clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can
be faulty. Replace with same type. If not check the waveguides within the cabin
for food particles that can burn and spark, check for rust that can corrode and
spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Set clock but time goes off
see this causes and fix it. God bless you
Door Switch
If the microwave runs for a few seconds and
then shuts off, a door switch might have failed intermittently. Check
each of the door switches for any signs of overheating, arcing, or
burning. Also check each of them for continuity. Replace any of the
switches that is visibly damaged or that only has continuity
intermittently.
Main Control Board
stops there may be a short circuit in the main control board. Check
other components first, these boards are often misdiagnosed
Touchpad and Control Panel
stops the touchpad and control panel might be defective. There are
several other components that can cause this problem, be sure to check
any other components before replacing this board.
Touchpad
stops the touchpad might be at fault. This is not common. Generally
speaking, if the dishwasher display is working and some of the buttons
respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
stops the high voltage transformer might have an intermittent short.
This is not common. Check other components related to the microwave
symptom first.
Thermoprotector
stops the thermoprotector may have tripped. This is a safety device to
prevent the microwave from overheating. It can be tested for continuity
to see if it's blown.
Thermostat
stops the thermostat might be defective. Watch our video on testing
thermostats.
Our Viking VMOS200 just stopped working. The
it has nothing to do with the magnetron. first you have to fix step one. then you will know if the magnetron is bad. its one or two of the primary switches on the bottom of the switch tower. usually with these mw if you dont press cancel to stop the mw, and you just push the latch to stop it, those wires heat up and cause the microswitches to burn and loose proper contacts. put a cup of water in the mw. set it to one minute and as its counting down. push on the latch LIGHTLY, as to not fully open the door and you will hear the magnetron kick on and the turn table start to rotate
Vmos200 microwave-set microwave timer goes down no power but when open switch is pushed in a little bit it works holding it in slightly
On these, this is usually due to a failing
bottom door switch, or its mount. Sometimes the door can also get misaligned due to slamming.See my help file on door switches
here.The Viking VMOS200 is essentially just a rebranded Sharp R-530E-series oven. The R-530E service manual is
here and it's helpful in working on your unit.All the internal parts will be the same, but outer parts are cosmetically different.
You can order Sharp parts from
Encompass here
or you can call them toll-free at
866-779-5835.
Viking Customer Support is at 888-845-4641.For Viking parts, on the West Coast call 1-800-488-9868. Otherwise call Hadco at 800-241-9152 or see
http://www.hadco.net.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
VMOC205 SS VIKING CONVECTION MICROWAVE
Hi this is tech crazy,he solution to the problem is as follows
Sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnatron, they replace
the whole oven.
There is a possiblity that the circuit that provides power to the
magnatron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it appart. It is a fairly
lengthy process however.
