20 Most Recent
SuperMicro LGA775/ Intel 946GZ/ DDR2/ PCI-E/ SATA2/ V&2GbE/ mATX PDSBMLN2 Motherboard Questions & Answers
Supermicro x9sra Boot up
file:///C:/Users/Wajiha/Downloads/MNL-1281.pdf
http://kernelpanik.net/boot-selection-menu-on-supermicro-x9sra/
Intel d915GLVG mother board vrm is short and fun dose not work
An electrolytic capacitor has failed.
If one has failed it indicates that the board has overheated, and many other components are also weak.
This Intel board is not of good quality.
Replace with SuperMicro or Tyan, and improve the cooling airflow in the case.
H8dce no audio
Usual cause.
Under the Chip Set Menu in the BIOS
Under South Bridge Configuration
The setting Audio CODEC Interface has been set to disable.
Linux drivers serial
The first place is always the Debian Linux website, because most Linux packages are derived from Debian.
Post code 38
"The BIOS can not shadow the ROM into system memory."
This is usually caused by the ROM on a card trying to use the same memory space.
Remember all of the ROMs have only the memory addresses from C800 to FFFF in the first megabyte available for shadow.
This was designed in in the first IBM PC and remains to this day.
Remove the other cards, and turn off both system ROM shadow, and video ROM shadow.
PDSMI
If you are good with a soldering iron the capacitors can be replaced.
Make sure you can wick the excess solder out of the holes.
Replace only with Japanese capacitors, and increase the airflow in the case and around the capacitor.
This is usually a sign of overheating.
What is system intilalization 2f
This is a video initialization error.
I have forgotten which one.
(I think the video RAM)
Check the graphic card, or the jumper on the motherboard, depending on the setup of the server. (On board video)
If on board video, also check the first DIMM pair.
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
