20 Most Recent
Nokia N78 Smartphone Questions & Answers
Hi I am using Nokia
Please remove the Memory Card and try again (try changing the wallpaper). In most cases, this problem is caused by virus or corrupted files saved on the Memory card (Maybe you didn't actually save them, but it's possible when transferring or in other ways). If even removing the memory card doesn't fix the problem, then please update the firmware or completely flash ( reinstalling the mobile's operating system) your phone. To do this, you better take it to a service center or to a mobile repairing shop, otherwise you may make mistakes which will be hard to get it work again.
Good luck.
Thanks for using FixYa.
2/25/2013 5:30:00 AM •
Nokia N78...
Answered
on Feb 25, 2013
My set phone cod lock
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
12/4/2012 11:50:22 AM •
Nokia N78...
Answered
on Dec 04, 2012
N78 can't send sms
i had same problem in n78 thay sms were not sending so i reset the phone not from factory settings i reset the whole set by pressing three buttons
9/2/2012 2:01:52 PM •
Nokia N78...
Answered
on Sep 02, 2012
Nokia N78 - Loudspeaker not working
tere bhan ka phoda kuti k bacha apni bhan rat ko bhaj dena solve ho jaye gi problem khuti k bacha gasti k bacha kangri maa ki najayaz aaulad tere ma ka phuda
6/24/2012 5:50:06 AM •
Nokia N78...
Answered
on Jun 24, 2012
Nokia n78 will not turn on
hi thanks for using fixya!
Try the following options.
1. Turn off your mobile unit
2. Remove the sim card
3. Remove the battery
After you do all those, install them back again, and try to turn on the power. If you are experiencing the same problem. I suggest you should bring your phone to a service center to further check the error.
Regards!
1/20/2012 11:22:21 PM •
Nokia N78...
Answered
on Jan 20, 2012
N 78 Bluetooth unable to search new devices
Users have encountered a lot of issues, bugs and problems with Nokia
N78, the first S60 device to support Feature Pack 2. If you are facing
issues with your smartphone, here are a few tips to get your mobile
phone back in business.
+ To restore your phone to the original factory default settings,
press the Menu button, then go to Tools, Settings, General, Factory
settings. Here you need to enter the lock code (generally 12345). After
the reset, the device may take a longer time to power on.
+ To hard reset/format Nokia N78 (all data will be lost), follow the below mentioned steps:
1. Turn off the mobile phone.
2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these three buttons, press the power button to switch on the device.
4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
pls reset the device fully and if no help pls update the OS dont worry
it is tested 100% may be in ur case the problem solves PLS RATE ME FIXYA if u like
12/5/2011 7:10:52 AM •
Nokia N78...
Answered
on Dec 05, 2011
I have forgotten N78 phone lock code can you help
Do a hard reset but keep in mind this will restore to its factory default settings
Turn off the mobile phone.Press and Hold the following three buttons: the green Call Answer
button, the “*” button, and the number “3′ button.While holding these three buttons, press the power button to switch on
the device.Release your fingers when the screen displays the Nokia Logo and the
www.usedcellphoneshop.com
10/31/2011 3:52:58 PM •
Nokia N78...
Answered
on Oct 31, 2011
