20 Most Recent
Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI Questions & Answers
Hi using a Biostar GF7100P-M7S VER 6.0 computer
Hi superdream32, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?2007 PC mobo the CMOS coin cell battery died.and useless now Nforce chip sets,zero support+7 + 2014 is end of life battery,you are 3 years over the line of battery deathh. so is first thing to fix. old Pentium D mobo, mostly useless nowropes:new coin battery installed9 stepshttps://www.pcdied.com/cmos.html#Reset_only.test the hdd,now.if bad no OS on earth runs on bad hdd. the manual on this PC has this huge blunderfails to say BIOS main hot key ! it is this, power on fast actions... both (2)disable NUMlock keyat power on and then hammer , keyreset bios thereand all setting there set correct.windows is last. not first.
2/9/2022 11:46:06 AM •
Biostar...
Answered
on Feb 09, 2022
When try to make the
That means the PSU( Power Supply Unit ) is not giving enough power.
Check the wattage of your PSU, it should be 500 watts or more to power up that MoBo or the PSU your using is not working anymore.
Hope that helps you out!
9/13/2011 7:21:27 AM •
Biostar...
Answered
on Sep 13, 2011
My motherboard Biostar GF7100P need to program
The first thing that I would do is check the MoBo's website and find a RAM compatibilty chart. Make sure that you Mobo doesnt have any know issues with your particular RAM. You may also check the RAM's website and look for compatible RAM for your MOBO. Rule this out first. The Sata F6 thing depends on the MOBO I think that most of the time you do have to f6 the drivers however on my ASUS this was not necsessay. My cut at this would be to take everything out of your system except for the few components that it requires to boot up and load the OS. RAM, Video Card, CD ROM, maybe the Floppy. Reformat your HD so that you can start over clean. Make sure that you have each cable plugged into the mobo correctly as well as the component. Reformat, then reload the OS. Start to load the system drivers one at the time rebooting after each is loaded. Pay attention to what you did last if the problem shows up again. This will probably point you to the issue. If every thing installs correctly without any problems then start putting the other hardware in one piece at the time loading the drivers andsoftware for each component then rebooting and ruung some stress test before moving to the next component.
1/19/2011 1:11:52 PM •
Biostar...
Answered
on Jan 19, 2011
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
7/9/2009 10:09:50 AM •
Biostar...
Answered
on Jul 09, 2009
Sound doesn't work on biostar gf7100p-m7s
it's a common problem of gf7100p-m7s series. Its depend on ur operating system. beoz many operating systems have their own audio drivers like windows vista. If u r using windows vista don't install audio drivers from ur motherboard disk. becoz i had faced this problem some months ago. if this is not hardware relative problem, u can see ur sound will work fine.
6/28/2009 3:42:39 PM •
Biostar...
Answered
on Jun 28, 2009
No video display
hello mr,carrera :) ...
i think u have only two choices u have to do :
1: you disconnect the power cable from you PSU , then reset the BIOS using the jumper pre-installed on your board , check the manual for this " Clear CMOS " ,,
then try again , if not then
2: u will have to replace your bios with an updated one of the exact motherboard model , you can do this easily cause Biostar have the socket of Bios ,not mounted in the motherboard ,,,
so, i am pretty sure that its a bios issue , like 95% ,,,,
the 5% u don't wanna know it ,,,,( Bad PSU might affected the power ct. of your Board :( ,,,, but try Bios 1st....
5/31/2009 9:23:36 PM •
Biostar...
Answered
on May 31, 2009
Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
3/4/2009 10:31:12 PM •
Biostar...
Answered
on Mar 04, 2009
NEED A part number for lighting harness for 2001
THIS IS A SPECIST AND FOR SERTAIN PEOPLE IN THE CAR INDUSTRY FOR THAT YEAR.
OTHER VANUES
USERS GROUP
HEMMING AUTO PARTS MAGAzine or BOOK STORE WOULD HAVE A BOOK, A PLACE THATS HAS OLD CARS AROUND, JUNK YARDS THAT CARRY THE CAR THAT PART # STAMPED ON THE HARNESS, PEOPLE THAT RESTORES THAT TYPE OF CAR, MUSUIME WHERE THEY MAY HAVE SOME ON THE FLOOR TO SEE WOULD HAVE THAT NUMBER IN THERE BOOK, CAR WIRNG OR WIRING HARNESS REBUILD, JC WETTNEY MAY BE ABLE TO HELP YOU, FIND THE ORIGNAL MANUFACTURE OF THAT PRODUCT THAN GOING TO THE LIBRARY LOOKINH UP THE MANUFACTURE INFORMATION AND WHO DID THEY SELL THERE INFORMATION OR WHO TOOK OVER THE BUSNISS AND CHANGED THE NAME OF THE COMPANY, SOME ONE SPECAILIST IN AUTOMOTIVE ELECTRACAL REPAIR OR FIXING THE DASH BOARD TYPE OF WORK MAYBE ABLE TO SEND YOU IN THE RIGHT DIRECTION
WHAT DOES THE CABLE CONNECT TO IT WILL GIVE YOU HINT WHERE TO START LOOKING FOR THE PART OR AND LOCATE WHERE IT WAS MANUFACTURE PLANT WAS AND IF ANY OF THE PEOPLE STILL LIVING THERE THAT MAYBE ABLE TO HELP YOU.
BEST OF LUCK FINDING YOUR INFORMATION
PS SWAP MEETS ALL OVER THE UNITED STATES ALL THE TIME , CALIFORNIA, BACK EAST JUST HAD ONE A FEW MONTHS AGO, THE HEMMINGS WILL GIVE YOU ALL THE SWAP MEETS AND AUTO TRDER MAY HAVE SOME INFO BUT HEMMING IS WHERE I WOULD START FIRST
ROD THE CANDYMANGNADY
2/17/2009 7:35:43 PM •
Biostar...
Answered
on Feb 17, 2009
Connect cd drive to biostar gf7100p-m7s
The 34 pin connector is for your floppy drive(s) .. not for your CD drive. There is no special cable for this. 2 different interfaces alltogether.
2/17/2009 11:40:06 AM •
Biostar...
Answered
on Feb 17, 2009
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
