20 Most Recent Carrier 52CQ-312-4 Comfort Series Heat Pump Air Conditioner Questions & Answers
Your local Carrier dealer or appliance parts house should be able to help you.
Carrier... | Answered on Nov 07, 2016
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Carrier... | Answered on Mar 11, 2015
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Carrier... | Answered on Feb 27, 2015
It really depends on the climate and the design. In Michigan where the winters are cold and the humidity high the air cooled heat pumps run constantly, but here in Arizona they cycle on and off like a regular air conditioner. That's the best answer I can give. Hope this helps and good luck.
Carrier... | Answered on Oct 14, 2014
Jump out limit switch blower should stop and inducer should come on then the heating sequences should start from there
Carrier... | Answered on Nov 29, 2013
Which coil?, indoor or out? Indoor coils freeze due to clogged filters, low freon, blower motor not working. Outdoor coil freezing could mean, in rare cases in cooling mode, reversing valve not shifting.
Carrier... | Answered on Oct 02, 2013
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Carrier... | Answered on Jul 01, 2012
It's with discharge pipe line(near to compressor)
Carrier... | Answered on Dec 25, 2010
Joe, If the system is only 1 year old I would guess it may still be under warranty. Check with the installing dealer. Might not cost a thing to fix it.
Carrier... | Answered on Oct 17, 2009
check fan rotation
Carrier... | Answered on May 31, 2009
Check the control board.
Carrier... | Answered on Apr 23, 2009
If the emergency heat doesn't come on very often, it will burn off debris that has collected on the heat exchanger causing the smell. Also, check that there aren't any chemicals that are being stored around the unit that would put out fumes that can be drawn into the system and when heated, cause the odor.
Carrier... | Answered on Mar 31, 2009
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
Carrier Heating... | Answered on Dec 10, 2019
try checking fan start up capacitor if motor runs see if ignitor trys to light if not bad board or ignitor
do you have a remote control? from there click mode until it is on heting
Carrier Heating... | Answered on Nov 15, 2019
possible bad transformer board is losing power that's why time is wrong
Carrier Heating... | Answered on Oct 19, 2019
Heating & Cooling Logo
Popular Tags
19 questions posted
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Heating & Cooling
Most Popular Question
wirein heat pump cooling only
  • Heating & Cooling
