20 Most Recent Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Questions & Answers
Keeps beeping
stuck door switch or mis coommunicating control board
3/9/2015 6:54:02 PM • Electrolux... • Answered on Mar 09, 2015
0answers
0answers
Free repair manuals and Support
Please click on : manuals
8/4/2012 11:27:19 AM • Electrolux... • Answered on Aug 04, 2012
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/30/2010 11:58:22 PM • Electrolux... • Answered on Sep 30, 2010
I got a Kenmore 3.5
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%&&
9/30/2010 11:56:20 PM • Electrolux... • Answered on Sep 30, 2010
My Kenmore 48102 washer is leaking from the bottom
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
9/30/2010 11:53:33 PM • Electrolux... • Answered on Sep 30, 2010
Just hooked up yesterday. Have done 3 loads.
It sounds like perhaps the shipping bolts are still in the machine. Look at the back you'll see 4 large bolts that must be removed to release the main tub assembly from the cabinet.
Refer to your owners manual and it should give you an illustration of where they are located.
Also make sure all four leveling legs are secured with the locking nut against the cabinet once it has been leveled.
Hope that helps,
Good Luck :)
10/28/2009 1:06:06 PM • Electrolux... • Answered on Oct 28, 2009
My kenmore front loader will
Either the selector switch is bad, pump or wiring to pump is bad, or the drain or drain screen is plugged. First check and clear the drain, Test power to pump with a voltmeter. If there is power, than pump is bad, If no power to pump, then selector switch is bad.
Copy and paste this link in your internet address bar under a new tab for more information on washer repair and feel free to ask any other questions:
http://www.howstuffworks.com/how-to-repair-a-washing-machine.htm
10/11/2009 8:03:45 PM • Electrolux... • Answered on Oct 11, 2009
Have a kenmore all in one washer dryer that will
firstly check the motor bushes as this can cause this problem.
7/15/2009 7:54:27 PM • Electrolux... • Answered on Jul 15, 2009
Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
2/20/2009 1:51:18 PM • Electrolux... • Answered on Feb 20, 2009
My Electrolux washing machine is blinking red with no time separator, can you help diagnose the problem. my model number is EWM09312
Here are some steps you can follow to try and identify the issue: Check the Door: The start button on your Electrolux washer may start blinking if the door to the washer is not closed properly. Try opening and closing the door again to see if the button stops blinking. Error Code Display: If the light only appears red, you can try the following manipulation to display the error code: Turn on your washing machine Simultaneously press the start button and the one to its left, usually the "end of cycle" button After a few seconds, the error code should be displayed Service Manual: For a more comprehensive diagnosis, you might want to refer to the service manual for your specific model. It contains a guide to diagnostics of electronic controls and troubleshooting based on alarm codes. ELECTROLUX EWM09312 SERVICE MANUAL Pdf Download ' ManualsLib Technician may have to replace PCB.
3/5/2024 3:53:37 PM • Electrolux... • Answered on Mar 05, 2024
I have an Electrolux model T5550 dryer coming error machine stop 10:15 what does this mean?
The emergency button has been pressed. Remove the emergency by pulling it out
2/25/2024 8:04:15 AM • Electrolux... • Answered on Feb 25, 2024
Electrolux EWT 604S Front Load Washer. It started intermittently leaking water under machine itself even when not in use. Anyone had the same problem? How did you resolve it?
Why Is My Electrolux Front Load Washer Leaking Water?
Advance Appliance Service https://advanceappliance.com > blog > electrolux-front... Oct 1, 2020 - A washing machine leaking from the front door usually means the door's gasket isn't functioning properly. When the door is closed, the gasket ... Missing: ewt ‎ 604s
Washing machine is leaking water
Electrolux UK https://www.electrolux.co.uk > support > laundry > wa... Jul 15, 2022 - Check if the leak is coming from the tap itself. Check the water supply connection to the inlet hose of the machine. Missing: ewt ‎ 604s
Electrolux Front Load Washer Leaking Water? ' D & T ...
D&T Appliance Service https://www.dtappliance.com > blog > electrolux-front... Aug 1, 2021 - If you find your washer leaking from the back it usually indicates an issue with the drain or water inlet hoses. Connection points are common ... Missing: ewt ‎ 604s
Electrolux Washing Machine - Washer Leaking Water
Repair Clinic https://www.repairclinic.com > RepairHelp > Electrolu... Here are the most common reasons your Electrolux washing machine is leaking water - and the parts & instructions to fix the problem yourself. .. Slip a sheet of newspaper under the bottom of the machine and it will indicate the area. If is does it when the machine is not running. My guess is that it is around the pump because some water always sits there, so either the pump body or the drain hose itself.
2/11/2024 11:22:29 PM • Electrolux... • Answered on Feb 11, 2024
Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Logo
25 questions posted
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
get repair manual kenmore front loader
  • Washing Machines
