20 Most Recent
Hamilton Beach 48274 BrewStation 6-Cup Coffee Maker Questions & Answers
Brewstation sounds like its boiling coffee after it's finished
It sounds like the sensor that switches from brew to keep warm is faulty... so it keeps boiling after it's brewed.
My suggestion to you is to clean it it with vinegar. The following link shows how to clean a ten-cup model. Just use smaller amounts for the six-cup model.
Good luck
https://youtu.be/mdigGqyI6iw
I am interested in purchasing this 6 cup brew
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
For a HamiltonBeach Brew Station 12 cup
You can, you need to contact hamilton beach to get a new filter, it sounds like that one is shot for sure. Their number is 800-851-8900. You should be able to just hit 0 when the recording picks up and get to a live person. Although it may be too late tonight still.
Tim
How do you get the
I made a video just for you and put it on the web on you tube.
http://www.youtube.com/watch?v=7dkk8jSClik
Hamilton beach flexbrew. Say “Fill H2O” but is is full. What do I do?
I was able to fix this:1. Remove top cover2. Remove grate, one screw3. Dump water4. Clean water sensor probe (silver colour, bullet shape, approx 1/4" long), use a small flat screw driver with paper towel to remove any build up.5. Plug in and test until it works.if you get it to work again, that would be a good time to run the vinegar solution through.
The coffee dispenser bar isn't working in my Hamilton Beach coffeepot 47900. Nothing comes out! Can I fix it?
There are a few possible reasons why the coffee dispenser bar on your Hamilton Beach
- Check the water level in the reservoir. Make sure that there is enough water in the reservoir to brew a full pot of coffee. If the water level is too low, the coffee dispenser bar may not work properly.
- Clean the coffee dispenser bar. Over time, coffee grounds and other debris can accumulate on the coffee dispenser bar, clogging it and preventing the coffee from flowing properly. To clean the bar, run a solution of equal parts water and vinegar through the coffeepot and then rinse it thoroughly.
- Check the filter basket. Make sure that the filter basket is properly seated in the coffeepot and that it is not clogged with grounds. If the basket is not properly seated or is clogged, it may prevent the coffee from flowing through the dispenser bar.
- Check the gasket. The gasket is a rubber seal that helps to create a tight seal between the carafe and the coffeepot. If the gasket is damaged or worn, it may cause a leak and prevent the coffee from flowing through the dispenser bar.
If none of these troubleshooting steps resolve the issue, it is possible that there is a problem with the coffeepot itself. In this case, you may need to have it repaired or replaced.
