20 Most Recent
Frymaster Dean FPEL4 Deep Fryer Questions & Answers
Orange flame
A orange flame means that not enough air is mixing with the gas to produce a nice clean burning blue flame. Try cleaning out any deposits of grease or anything else that could be blocking the air pathway to the flame.
WE ARE SEARCHIG FOR THE
Please let us know the complete model number of the product.
You can view the complete list of models on the manufacturer's website by clicking this
link. Click on your model and on the next page which opens, you can download the instruction manual.
Thanks for using
FixYa.
FRYMASTER SERIES-AD DO'NT LYTE (BURNS)
HI.If electric circuit you said is working and seems no problem.there might be a problem with the filament of the burner.This filament is responsible in producing heat or producing flame that burns the burner..Hope this idea helps..
How to clean blocked pilot orfice
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
Can anybody tell me what's wrong with this? Any suggestions please and thank you.
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
