20 Most Recent
Oster 6058 Toaster Oven with Convection Cooking Questions & Answers
Clock runs fast -- gains
Digital Clock - Much like a digital watch or a computer, the 12/24 hour Real Time Clock (RTC) digital display clock's ability to maintain time with integrity is most likely on the interior. Flip the unit to view the rear and you'll find a backplate with phillips screws and 4 star bit screws of different size each hidden by black rubber gromits).A Common Battery that can be found at your local retail store:RTC 2032 3 Volt BatteryI can only assume removing the screws would reveal the proper answer, but I wager a standard RTC battery is what you'll find.
Pizza and oven bottoms are not working but others.
If they went bad maybe they can be replaced. Here is an address that will give you a list of sites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Model# 6058 toaster oven won.t
You need to remove the top cover and check for a bad fuse if no display. If you have display, then it could be a bad door switch, or a bad megaton, or na bad high power Diode.
The bottom two heating elements
I do not know everything about every toaster oven out there, but I would guess that they can be replaced. Here is an address that will bring up a list of sites that sell parts. Maybe one of them can be of more help.
When I went to use it last week the elements would
hi jackie, the loud noise can be an excessive power drain and that is why the elements will cut off at times. There are some thermal fuses or resettable thermal switches that are built in the oven and will cut the power to the element circuit to protect the whole oven. My suggestion is to have an appliance tech check the unit for this problem because the fuses or switches are inside the electrical area of the oven.
