20 Most Recent LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
0answers
How do I troubleshoot my LG refrigerator model:LFC20760ST that has stopped working?
Disconnect the power cord wires on the fridge side after you unplug the cord....for continuity on each wire.
5/15/2017 10:25:35 PM • LG LFC20760ST... • Answered on May 15, 2017
Refrigerator is getting no power compressor does
If it feels like the whole thing is dead in the water, then it is probably your fuse in the back. always include the year and the make of your unit. then people can help more. fuses on modern refrigs are mounted on the circuit board in the back and have to be soldered off and on.
3/8/2014 9:07:26 PM • LG LFC20760ST... • Answered on Mar 08, 2014
0answers
0answers
0answers
Lfx25778st
Be the first to answer 12/15/2013 5:32:37 PM • LG LFC20760ST... • Posted on Dec 15, 2013Be the first to answer
In LG bottom freezer ice crystals are forming on everything. what could be happening?
Getting moisture in unit, check around door seal for leaks our open spots
8/20/2012 12:55:25 AM • LG LFC20760ST... • Answered on Aug 20, 2012
The refrigerator portion appears to
First check this things, is the compressor and fan on the compressor running. Mostly it will run, because in most of the cases it runs. ---------- Now I will explain the error code:---
There are two types of error code which comes up on your refrigerator.
-------One is 6 and 7 separate error code and other is combined 67 combined error code.
----As per most of the cases on this LG model refrigerator you are getting error code 67,
The error code only 6 is run capacitor for compressor and error code 7 is problem with compressor
But if compressor and its components are running quite smoothly. Then its error code 67, which in most of cases been noticed. so as per error code, the fan motor is issue.The evaporator fan motor issue.The evaporator fan located in the freezer section.This motor for fan is getting inside over heat and looses its communication with main board.
As per error code, the fan motor needs to be replaced. ----------
This will help.Thanks.Helpmech,.
9/13/2011 3:12:07 AM • LG LFC20760ST... • Answered on Sep 13, 2011
I cleaned my refrigerator out
unplug the fridge and plug it back in after a couple of minutes. this will reset the control board located behind the fridge. if after plugging it back in, it doesn't work, then you need to have the board replaced.
7/16/2011 7:44:33 PM • LG LFC20760ST... • Answered on Jul 16, 2011
Our LG LFC20760S refrigerator/freezer coldness
That MIGHT be the control board but before you order anything you should check the thermistors. The board relies on data from them thermistors. If one is out of spec or even out of spec then that throws a monkey wrench in the works. What you need is a manual which shows the locations of these thermistors and some diagnostics info. French Door Service Manual If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/4/2011 12:40:10 AM • LG LFC20760ST... • Answered on Jan 04, 2011
LG LFC20760ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
40 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
in lg bottom freezer ice crystals
  • Refrigerators
