20 Most Recent
Crosley 24 in. CDU600 Built-in Dishwasher Questions & Answers
Water is running in and draining right back out.
Was it the float? try this empty machine put 1cup of vinegar or CLR and let it run through machine and clean jets and spray arm as well as soap dispenecer,You may want to try cascade they have rechanged it .Try this and let me know thanks
Water won't come into the dishwasher
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
No water
Mike,
It's possible that your flood/safety switch inside the DW is stuck. Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (It has to be all the way down to allow water) Now try your DW.
SG
Dish washer problem
Please check the water supply is turned on before proceeding.
If it is, the supply to the internal water valve needs to be checked, and the valve for correct operation.
The machine will pause untill it has enough water in it - no water , and it won't advance.
Check out the water supply side of things to get it going again.
Thanks for using Fixya
No spray
This sounds like the circulating pump motor is either defective or the linkage is broken. If it makes no noise when it should be washing. then it probably requires a new pump motor.
It's normally located at the lower front right of the machine, but turn off and unplug before removing covers.
If you just get a motor sound - you may just need the linkage.
The problem is sometimes caused by broken glass inside the pump assembly - so use care when handling.
The detegent doesn't completely leave
This model relies on the top spray arm to 'wash' the detergent out of the soap dispenser - and that is the problem. Your top spray arm will not be turning properly. Check the angled jet on the very tip of the arms for blockages with food or fruit pips etc - it's this angle only that makes the arms turn.
if blocked, clean out with a pin or wire, and running water - make sure you get every bit out. If not, buy a new spray arm. If the arm is split, you will need a new one.
Other problems may be low water level or a faulty circulation pump - BUT check the spray arms first.
Remember a dishwasher is NOT a garbage disposal unit, so scrape any food particles of plates etc before putting them in the machine. Run a dishwasher cleaner through with no load once in awhile.
2/4/2018 6:27:42 PM •
Crosley...
Answered
on Feb 04, 2018
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
2/5/2016 5:41:45 PM •
Crosley...
Answered
on Feb 05, 2016
Dishwasher handle won't lock
The top locking tab attached to the counter top may be misaligned. Bend it down slightly to make a positive connection with the door locking portion. Check the level adjustments on the front right and left corner of the washer. It is behind the face plate or skirt on the front of the washer.
3/18/2014 11:46:20 PM •
Crosley...
Answered
on Mar 18, 2014
