20 Most Recent
AMI Atlas (7572600000) Motherboard Questions & Answers
Have a Rowe AMI R-87 model, 200 play. Record
Hi Jim,You can purchase the service manual from an online store. Here is the
link to an online store.Regarding the original problem, please post the problem under the appropriate category on FixYa website so that the best experts in that category can view and post the solution. (
You have posted the question under computer motherboards section)Thanks for using FixYa.
12/18/2011 12:46:06 AM •
AMI Atlas...
Answered
on Dec 18, 2011
I dont have cd draiver.
if you are referring to your cd rom driverClick start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
7/14/2011 11:22:41 PM •
AMI Atlas...
Answered
on Jul 14, 2011
How do you clear the map in a rowe ami laserstar nostaglia cd jukebox
hi
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Testimonial: "Hi Alan Do you have a website etc as I have two jukeboxes both AMI Rowe, one is a Ti2 this has a speed and selector,problem, the newer one I just need guidance on it plays ok this is an R-91 Many thanks Lisa"
How to Troubleshoot Beep Codes Is Your Computer Beeping? Here's What to Do
Is your computer making a beeping sound when it starts... and then doesn't really start? No, you're not crazy, your computer really is beeping, and the sound may be coming from
inside your computer, not your speakers.
These beeps are called
beep codes and are used by the
BIOS (the software that runs your computer
hardware) during the
POST (an initial test to make sure your computer is OK to start) to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the
motherboard has encountered some kind of problem before it was able to send any kind of error information to the
monitor. The beeping, then, is a way to communicate a problem to you when the computer can't show a proper error on the screen.
Follow the steps below to determine what computer problem the beep code is representing. Once you know what's wrong, you can work to fix the issue.
Figuring out why your computer is making beeping sounds should only take 10 to 15 minutes. Solving that problem that you identify is another task entirely and could take a few minutes to hours, depending on what the problem ends up being.
- Power on the computer, or restart it if it's already on.
- Listen very carefully to the beep codes that sound when the computer begins to boot.
Restart your computer if you need to hear the beeping again. You're probably not going to make whatever problem you have worse by restarting a few times.
- Write down, in whatever way makes sense to you, how the beeps sound.
Important: Pay close attention to the number of beeps, if the beeps are long or short (or all the same length), and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
I know this might all seem a little crazy but this is important information that will help determine what issue the beep codes are representing. If you get this wrong, you'll be trying to solve a problem your computer doesn't have and ignoring the real one.
- Next you'll need to figure out what company manufactured the BIOS chip that's on your computer motherboard. Unfortunately, the computer industry never agreed on a uniform way to communicate with beeps, so it's important to get this right.
Or you could try to turn off the beeps from the bios.
The easiest way to figure this is out is by installing one of these free system information tools, which should tell you if your BIOS is made by AMI, Award, Phoenix, or another company. If that doesn't work, you could open your computer and take a peek at the actual BIOS chip on your computer motherboard, which should have the company name printed on or next to it.
Important: Your computer maker is not the same as the BIOS maker and your motherboard maker is not necessarily the same as the BIOS maker, so don't assume you already know the right answer to this question.
- Now that you know the BIOS manufacturer, choose the troubleshooting guide below based on that information:
Using the beep code information specific to those BIOS makers in those articles, you'll be able to figure out exactly what's wrong that's causing the beeping, be it a RAM issue, a video card problem, or some other hardware problem.
More Help with Beep Codes
Some computers, even though they may have BIOS firmware made by a particular company, like AMI or Award, further customize their beep-to-problem language, making this process a little frustrating. If you think this might be the case, or just worried it could be, almost every computer maker publishes their beep code list in their user guides, which you can probably find online.
See
How to Find Tech Support Information .
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
