20 Most Recent
Bulova Harley Davidson Pendant . Locket Feature. Silver Glitter Patterned Dial. Crystal Accents. Snap Open Cover with Open Bar and Shield Logo. Stainless Steel Case and 30" Curb Chain Watch for Women Questions & Answers
Can't open Geneve OGW154 gold wrist watch to replace the battery
You are right, this type of watch can be opened by lifting crystal and extruding the stem. As for lifting the crystal you need a specialized tool, there is no other way then to go and find your nearest watchmakers shop. If you will try to lift the crystal using knife or any other unspecified tool, you will damage the crystal. Even if you will be lucky enough to get it out without any damage, you will not be able to fit it back, because the watch crystal setting tool reduces the crystal diameter for easy fitting.
Best solution for you is to see the watchmaker and ask for help.
Do not forget to rate, please.
The push button function on swiss model 2423.11 bulova accutron.
Jesus I can't believe no one answered this guy with even an "I don't know." in 6 years. If it's like my watch, it's for synchronizing the second hand. If you press the button on the minute mark from the NIST time web site, when your watch is ten seconds fast, the second hand will stop for ten seconds. This makes your watch match the time clock. The really cool thing is if your watch is SLOW, if you press the button on the minute mark when your watch is twenty seconds behind the NIST time web site, the second hand will SPEED UP until it matches the NIST time. Very cool and this is **totally from my memory** because I just got my watch back from Bulova but I forgot to ask about the button.
How to set a Bulova maritime watch
https://www.bulova.com/pages/manuals-parts
User Manuals
Please consult the user manual that was packaged with your Bulova watch. If you don't have your Bulova user manual, please view our
STANDARD MANUAL to read general information about how to set and maintain your watch.
You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, and we'll find it immediately.
For all other inquiries or assistance, please contact
[email protected] or call 800-233-3350.
Parts Manuals
What battery does the Bulova C837381 take and how do you put back on?
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
Set time on mz berger aw 205 388 sport watch
I just got a M.Z. Berger AW206 366 so the setup should be identical.
The watch has four buttons total. I'll name then by their positions. Top Left (TL), Top Right (TR), Bottom Left (BL), and Bottom Right (BR).
(BL) is your mode switch. Press it once at a time to toggle between modes, (Time, Chronograph, and Alarm). From the Time mode press (BL) three times. This will put you back in time mode with the seconds flashing. Press (TR) to toggle seconds back to '00'. Press (BR) to toggle to the next setting point, and (TR) to advance it. Just keep pressing (BR) until all the settings points are the way you want them. Note: In time setting mode it only advances the setting forward when you press (TR). So when using it to change hours display for 12/24 hour display or daylight savings time you just have to keep advancing the hour until it shows up correct. There is no DST or 12/24 display toggle on this watch. You just have to change the hours display manually. To exit time setting just press (BL) once.
