20 Most Recent Guess G95290G (Size: ) Watch for Men Questions & Answers
How do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
2/10/2018 4:04:00 AM • Guess G95290G... • Answered on Feb 10, 2018
How do i change the battery on a guess waterpro
If the watch is waterproof then you need a special wrench to remove back. If it is not then you can pry the back off with a fine knife blade. You can then change the battery. Most if the time it is easier to go to a watch shop and have them put in a new battery. Usually about 5 to 10 dollars.
11/23/2009 6:35:54 PM • Guess G95290G... • Answered on Nov 23, 2009
How do activate the chime on a Linden 31 day wall pendulum clock?
I have same exact problem, did you ever find an answer?
11/13/2023 8:04:48 PM • Guess Watches • Answered on Nov 13, 2023
3answers
Where is the serial number on a guess watch
if you can't see it on the back, it's probably inside the back cover.
2/8/2023 9:54:10 AM • Guess Watches • Answered on Feb 08, 2023
Where is the serial number on a guess watch located
110163L1
11/14/2022 7:14:12 PM • Guess Watches • Answered on Nov 14, 2022
Guess Watch. What is the function of the left dial on it please?
Question edited for clarity. It would depend on the model as they make a few! This one looks like it is a 24 hour 'Military Time' dial? https://www.guess.com/us/en/women/accessories/watches/rose-gold-tone/rose-gold-tone-multifunction-watch-multiplecolors/GW0365L3-MULTI.html Contact them and ask
Contact us
Call Contact Chat https://www.guess.com/us/en/women/accessories/watches/view-all?lvpid=GW0465L1-GLD ...
8/23/2022 1:37:11 AM • Guess Watches • Answered on Aug 23, 2022
Battery for Guess watch G85388G
https://watchgnome.com/2016/12/guess-watch-battery-size-guide-sizing/#:~:text=What%20Size%20Battery%20Do%20Guess,SR920SW%20or%20SR626SW%20watch%20batteries. "Guess Watches Usually Take 377 or 371 Batteries" 377 batteries have many equivalents that can be cheaply purchased and tested to see if they work or not. https://www.battery-house.co.uk/377_button_cell_battery
6/15/2020 9:39:15 AM • Guess Watches • Answered on Jun 15, 2020
I want to replace my watch leather strap Guess collection 30000
Go to the shop, where you bought it and ask if they can change it.
3/12/2019 7:09:14 PM • Guess Watches • Answered on Mar 12, 2019
How do I change the battery on a Guess WO872G2 watch
Here's a Youtube for changing the battery or flip the strap inside out and use a small kitchen knife to pry off the back where there is a small lip. I used a magnifying glass to find it near the strap. https://www.youtube.com/watch?v=d9E7G-ajBn0
12/29/2018 11:43:22 PM • Guess Watches • Answered on Dec 29, 2018
0answers
0answers
Guess G95290G (Size: ) Watch for Men Logo
Popular Tags
7 questions posted
Top Guess Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Guess Watch Expert? Answer questions, earn points and help others
View Most Popular
Guess Watches
  • Guess Watches
Most Popular Question
adjust band guess g95290g guess steel
  • Watches
