20 Most Recent Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds) Questions & Answers
(Mpc 1000) Only right Channel Produces sound
Are you recording, writing, sampling in mono or stereo?
2/21/2019 3:54:23 PM • Akai MPC-4000... • Answered on Feb 21, 2019
0answers
0answers
2answers
Mpc 2000
the screen has probly burned out.. u need to get it replaced
9/5/2012 4:20:51 AM • Akai MPC-4000... • Answered on Sep 05, 2012
0answers
When I try to load
I have same problem, havent figure iyt out yet since 2month ago when i got my mpc4000. Can anybody help please mail [email protected] Cheers /Martin in Sweden
6/24/2011 10:21:40 AM • Akai MPC-4000... • Answered on Jun 24, 2011
2answers
I have no sound from
Hi nappybutbald,
I see that you are epxeriencing issues with you Akai MPC-4000 Plus Machine.
Basing from what you mentioned on what is happening it shows that you maybe experincing issues related to the setting or the compatibility of your software.
You just may need to changes some setting or probably update you software.
Check the link to see updates for your Akai - http://www.akaipro.com/mpc4000
I hope that this helps regarding your concern.
Have a nice day,
mvincentc
5/25/2011 3:21:49 AM • Akai MPC-4000... • Answered on May 25, 2011
I have no sound from my MPC 4000 while in main
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
5/23/2011 8:21:43 PM • Akai MPC-4000... • Answered on May 23, 2011
3answers
Akai MPC 400 Plus Drive Crash
u go to dos mode to using boot disk or ,press F8 after post screen,then select dos mode and type in dos mode as 'chkdsk'
follow onscreen instruction ,thats all ,thats ok ,restart the pc then try again ,thats working i hope
regards
prasanna
2/24/2011 8:05:41 AM • Akai MPC-4000... • Answered on Feb 24, 2011
Not seeing the harddrive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
1/12/2011 1:23:16 AM • Akai MPC-4000... • Answered on Jan 12, 2011
MY HARD DRIVE WAS COMPLETELY
If your hardrive was COMPLETELY erased, then there is no OS or anything on it.. which then needs to be partitioned, and formatted
12/21/2010 1:38:55 AM • Akai MPC-4000... • Answered on Dec 21, 2010
Hi, I have an mpc 4000 and somehow I can't get it
Hi - I thought this solution I read earlier may help you out - it was originally posted for another problem:
http://www.fixya.com/support/t519740-akai_mpc_4000_plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
12/16/2010 8:59:21 AM • Akai MPC-4000... • Answered on Dec 16, 2010
I can't hear any sounds
Have you loaded sounds for the pads from an internal or external storage device? (Such as CD or Internal Hard Drive, if installed) - each time you turn on the power, the programs are cleared so the pads will not make any noise until you load the sounds you want.
Otherwise, it could be related to your speaker setup?
Provide some details on your system setup and whether you are loading programs etc.
12/16/2010 8:51:50 AM • Akai MPC-4000... • Answered on Dec 16, 2010
My mpc 2000 wont load the boot disk when i insert
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
9/21/2010 11:59:33 PM • Akai MPC-4000... • Answered on Sep 21, 2010
I dont have sound in
9/9/2010 4:35:11 AM • Akai MPC-4000... • Answered on Sep 09, 2010
Formatting an akai disk
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
8/27/2010 2:26:37 AM • Akai MPC-4000... • Answered on Aug 27, 2010
2answers
My Aspire one Lap top sound is not working
Hi, first check in control panel, speekers; to see you sound is set correctly. If so, under control panel go to System, hard ware then device manager and click the + to open your audio device, if there are any problem you will see a yellow ?; right click over audio and try updating your driver.
Hope this helps.
7/7/2010 8:21:26 AM • Akai MPC-4000... • Answered on Jul 07, 2010
Required sound card driver for (model jil-7000) on
Download the VIA KM 400 motherboard drivers from here.
Hope that helps.
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
6/15/2010 8:53:22 AM • Akai MPC-4000... • Answered on Jun 15, 2010
Computers & Internet Logo
Popular Tags
58 questions posted
Top Akai Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry Ng
Larry Ng
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Computers & Internet
Most Popular Question
no sound from
  • Computers & Internet
