20 Most Recent Topeak HeadLux Helmet Light - cycle lights Questions & Answers
How to open headlux to replace battery
Turn the strap 90° counterclockwise to unlock the battery cover. Replace with two (2) CR2032 batteries, positive (+) side up. headlux-gb-0912-3xuxc12vkhqw4zacw5xap2yj-4-0.jpg
2/3/2019 3:25:38 AM • Topeak HeadLux... • Answered on Feb 03, 2019
0answers
My Joe Blow Pro will only pump up to about 40 to
Most likely a problem with the check valve - try this: "Make sure the Check Valve at the bottom of the pump is inserted correctly. Unscrew the rounded nut just above the foot rests, pull out the spring and black thingy. The pointy black thingy (check valve) must be inserted first, pin in first, then spring behind it, then small black rubber O ring. One of my four kids (or me?!) must have switched it, because spring first. it would not pump (bounced back and gauge said zero after every pump). Put it in black valve first, and it worked like new. If this does not work for you, it is possible that you need a new check valve, about $3." Joe Blow Sport Floor Pump Problems I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
9/14/2017 6:35:56 PM • Topeak Cycling • Answered on Sep 14, 2017
Topeak comp 150 directions
If anyone still needs a Topeak Comp 150 manual, it's still available for download from here: http://www.m.topeak.com/mediafiles/assets/177 They haven't made it easy though.
5/8/2017 12:00:56 AM • Topeak Cycling • Answered on May 08, 2017
0answers
Wedge bag
Be the first to answer 4/15/2014 7:00:22 AM • Topeak Cycling • Posted on Apr 15, 2014Be the first to answer
Am trying to get hold
It's not even listed at Topeak's website but if anyone knows where it is they do.
http://www.topeak.com/Service/usa_customer_service
9/13/2011 2:08:08 AM • Topeak Cycling • Answered on Sep 13, 2011
I have a comp 130
Here is a link to the Topeak Support website:
http://www.topeak.com/Service/Downloads
And here is a direct link to the User's Manual download for the 130 computer:
http://www.topeak.com/mediafiles/assets/163/file/1
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
After you click on that button, it will ask you if you want to open or save the file.
Choose OPEN.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
8/15/2011 1:31:20 AM • Topeak Cycling • Answered on Aug 15, 2011
Topeak tune-up stand dx where
Maybe use a search engine? "topeak dx tune-up bike stand"
eBay has one but it's only one step up from this...
http://cgi.ebay.com/Minoura-Bicycle-Y-Work-Display-Stand-MBT-ROAD-new-/380341432878?pt=LH_DefaultDomain_0&hash=item588e1db22e
http://cgi.ebay.com/Topeak-Tune-Up-DX-Bicycle-Stand-/250773594758?pt=LH_DefaultDomain_0&hash=item3a63456286
But for the same money you could get a genuine Parktool PCS-9 workstand and stand up while you work...
http://cgi.ebay.com/Park-Tool-PCS-9-Work-Stand-Bicycle-Repair-Stand-PCS-9-/300521614457?pt=LH_DefaultDomain_0&hash=item45f87bec79
or look on a search engine for others.
8/13/2011 11:04:03 PM • Topeak Cycling • Answered on Aug 13, 2011
Just trying to figure out
Search engine "install the topeak aero wedge pack" takes you right to it - immediately.
http://www.topeak.com/products/Bags/AeroWedgePack_large_Quick
The manual is there to download.
Fixya experts need not be in the loop. You could have had your answer, um, 6 hours ago.
8/4/2011 2:18:03 AM • Topeak Cycling • Answered on Aug 04, 2011
I need a TwinHead replacement.
Good luck. Topeck Joe Blows are great pumps and reasonable. You may be able to contact Topeck for a replacement.
7/2/2011 6:54:03 AM • Topeak Cycling • Answered on Jul 02, 2011
Topeak Pocket Shock pump~ can't
When you place the pump head on the valve make sure you flip the lever, this will seal the pump and air will not come back out. Also make sure your valve is not bent or loose. If your still losing air take the pump and bike into any bike shop and they will be more than happy to show you how to use it, and bonus if there is something wrong with either the tube or pump they will be able to diagnose and provide a solution.
4/7/2011 3:43:08 PM • Topeak Cycling • Answered on Apr 07, 2011
Topeak HeadLux Helmet Light - cycle lights Logo
2 questions posted
Top Topeak Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
View Most Popular
Topeak Cycling
  • Topeak Cycling
Most Popular Question
open headlux replace battery
  • Cycling
