20 Most Recent DKNY NY1304 Watch for Men Questions & Answers
Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
Br. M
DKNY NY1304... | Answered on Jul 31, 2010
You have to speak to your nearest DKNY distributor - they might help you and carry out necessary repairs. Alternatively visit your nearest watch repair shop and ask if they can help.
I advise you to contact the customer service department of DKNY
DKNY Watches | Answered on Oct 26, 2018
Google (DKNY)(4915)(manual) without parens.
DKNY Watches | Answered on Sep 09, 2018
Fixya is unable to suggest sources of watch bands.
DKNY Watches | Answered on Mar 28, 2018
Take your DKNY watch to a jeweler for a demonstration of how to remove the back without mangling it. You may even be able to persuade the jeweler to install a new battery - all for a reasonable sum.
Take your DKNY watch to a jeweler for a demonstration of the non-destructive way to remove the back. You may even be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
DKNY Watches | Answered on Mar 25, 2018
If it were working perfectly, the hands would move. The watch may be defective.
DKNY Watches | Answered on Dec 14, 2017
look on the battery or take it in and they will tall you what kind
DKNY Watches | Answered on Nov 23, 2016
If you look at the movement inside the watch it should be possible to find the movement number (you might need a loupe or magnifying glass to see it clearly) and name (e,g, Seiko-Epson, Miyota etc.)
If you can supply that information I can tell you which battery it requires.
DKNY Watches | Answered on Oct 12, 2016
please see attached website.www.esslinger.com/watch-crystals/
DKNY Watches | Answered on Jul 16, 2016
If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
DKNY Watches | Answered on Jul 07, 2016
http://www.watchstation.com/wcsstore/CommonWatchStation/content/shell/brand_guides/DKNY/instructions/DKNY_Inst_ENG.pdf
DKNY Watches | Answered on Jun 05, 2015
DKNY NY1304 Watch for Men Logo
Popular Tags
2 questions posted
Top DKNY Watches Experts
Janelle Schoonover
Janelle Schoonover
ray gallant
Harrie
Are you a DKNY Watch Expert? Answer questions, earn points and help others
View Most Popular
DKNY Watches
  • DKNY Watches
Most Popular Question
bought
  • Watches
