20 Most Recent
Adobe Illustrator CS2 for PC Questions & Answers
How to view content damaged ai file after formatting?
Hi
Here are a few tricks that might help. But no guarantees ;-)
Are the file types hidden? If so make them visible. (unhide) Then you can see if they are .ai or something else. If they have been changed try to make a copy of the file (for safety) and add the correct file ending. If this does not work try adding the file ending .pdf right click on the file and open with adobe illustrator.
You might get lucky
1/17/2015 4:59:55 PM •
Adobe...
Answered
on Jan 17, 2015
Adoobe Illustrator problems
HAPPENS REGULARLY IN ALL FILE TYPES. SAVE AS NEW MORE FREQUENTLY AS THIS CAN OFTEN HELP REDUNDANCY PROTECTION
11/26/2014 5:54:54 AM •
Adobe...
Answered
on Nov 26, 2014
What is the authorization code illustrator cs2
Adobe illustrator cs2
s/n 1034 - 1908 - 3831 - 7484 - 1994 - 9390
Activation no 3316 - 7184 - 7315 - 5802 - 5493 - 7912 - 8136
Activation type : Normal 93: -8
i have Authorization Code
11/20/2014 11:39:32 AM •
Adobe...
Answered
on Nov 20, 2014
Correct the offending command
1.Launch Illustrator.
2.Using File > Open, hold down Command + Ctrl + Alt + Shift (Windows), and click Open. Double click the file to open. You want the full Open dialog.
3.Your file will be blank. Close the file without saving or altering.
4.Go back to your directory. You will now have a second file with an underscore at the beginning of the filename. (
myfile.aivs.
_myfile.ai).
11/5/2014 6:10:14 PM •
Adobe...
Answered
on Nov 05, 2014
Adobe illustrator cs2 request code
I want to mention that the activation server for the Adobe CS2 products were removed and hence the CS2 and previous version can not be activated now.
If you have purchased the Illustrator CS2 then you can contact Adobe support and then they would provide you an alternate to get the Illustrator CS 2 working.
Regards
Anand
9/7/2014 4:26:10 AM •
Adobe...
Answered
on Sep 07, 2014
