20 Most Recent
Olympia CDP24200 Cordless Phone Questions & Answers
Cdp24201 base handset wont work
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
Software cdp 24106
There is no such thing, Olympia went out of busniess before Vista was released. Try setting the program to open in windows XP mode. Not sure how it's done in Vista but I know in XP you could open applications in Windows 98 or 95 mode.
Wont come on.has key sign
The key sign means that the phone is locked and you must enter a security code to unlock it.
Have you a code?
4310-WONT MEMORISE LONG DISTANCE ACCESS CODES ALSO
Unfortunately the manual for your product is not available in English, so I can only give you general instructions.
The 16 digits limit is normal and depends on phone specifications. 16 is the maximum size for stored number.
If the number is not being stored , that may happen because you are using a number that the phone does not recognise as valid. Probably this phone does not allow call transfer to this kind of number.
Ensure that you are following thoroughly the instructions, if the phone is not storing settings , then the number entered is not valid.
Test distance access code with a different number.
Also ensure that you are using the phone in the country where the phone was originally purchased, or the phone may not work as it should.
