20 Most Recent
Electro Brand Nostalgic Stereo CD Music System Shelf System Questions & Answers
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
The headphone socket
When you move the headphone plug around and the sound cuts in and out that usually means that the terminals in the jack have corrosion on them. You can usually clean the jack with contact cleaner that is sold in home improvement stores.
Here's a video showing how to clean the headphone jack on a phone but the process is the same for any device that uses a headphone.
How to Repair a CD Player on a Electro Brand Model 9222 Turntable AM/FM Radio with CD Player
not really repairable none of them are unless the laser itself died byut even then it isn't really repairable the only way would be to find the same type of unit and swap out the good cd player with the bad one but rather than go thru that just buy a new or nice used one no sense rebuilding this junk they really were throw away units it breaks/ you trow it out simple easist cheapest way out...buy another one used and be happy
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
