20 Most Recent Casio fx-300ES Plus Scientific Calculator Questions & Answers
Not giving proper awnsers for square root questions
Contrary to what you believe, results with square roots are exact. Decimals are approximate. Press the SD key to convert from standard to decimal representation.
5/22/2018 12:30:37 AM • Casio fx-300ES... • Answered on May 22, 2018
Need help typing x10^-3. Giving a syntax error on casio fx plus.
After entering the mantissa, press x10^x (middle of the bottom row) then (-0 (fourth key, left column) then 3. For example, to enter 4x10^-3, press 4 x10^x (-) 3 .
8/30/2016 10:00:33 PM • Casio fx-300ES... • Answered on Aug 30, 2016
My screen broke.
Just buy a new one.
10/16/2015 11:04:04 PM • Casio fx-300ES... • Answered on Oct 16, 2015
How to change fraction answers back to decimal answers
Press the S--D key just above the DEL key to switch a single value between symbolic and decimal forms. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
1/23/2014 12:50:51 AM • Casio fx-300ES... • Answered on Jan 23, 2014
I want the answers to be decimals
Press SHIFT MODE 2 to select the LineIO mode. See page E-7 of the manual: http://www.fixya.com/support/p8622494-casio_fx_300es_plus_scientific_calculato/usermanual-3B0D874-pdf
1/23/2014 12:48:20 AM • Casio fx-300ES... • Answered on Jan 23, 2014
How do I do polynominals
What do you want to do with polynomials? Evaluate them for certain values? Find their roots? Combine two or more of them?
4/29/2013 6:13:06 AM • Casio fx-300ES... • Answered on Apr 29, 2013
When I add something the answer is always in a fraction. How do I fix it???
Press SHIFT [SETUP] 2 to switch to the LineIO mode.
11/13/2012 8:08:16 PM • Casio fx-300ES... • Answered on Nov 13, 2012
How to Convert a 4-digit decimal no. to the binary format in Casio fx-991MS
The way to do it is this; Divide the number by 2, get the integer quotient for the next iteration. Get the remainder for the binary digit, repeat the steps until the quotient is equal to 0.
3/22/2024 7:20:35 AM • Casio Office... • Answered on Mar 22, 2024
My casio F-28W is showing (complete display ). What is its solution
It is because it is not set up correctly. For you to fix it, just press on the lower right button for few seconds till it displays " cas10" then let go of the button
3/11/2024 12:58:15 PM • Casio Office... • Answered on Mar 11, 2024
Casio Add Mach DR-120R - not printing correct numbers. 0 for 1, 1 for 2, etc. Recently had to remove ribbon from gears. Tried re-setting it, but it did no good.
Here is the Service Manual, but in normal instances, you would just buy another one, or return it to Casio for service.
Casio DR-120LB Service Manual
ManualsLib https://www.manualslib.com > ... > DR-120LB View and Download Casio DR-120LB service manual online. DR-120LB cash register pdf manual download. Also for: Dr-200l, Dr-210l, Dr-320b, Zx-517c, Zx-517a, ... ..
2/28/2024 6:17:34 AM • Casio Office... • Answered on Feb 28, 2024
My screen says [Dec] and I cant do normal calulations with it there. I have a casio fx-991EX calcultor
If your Casio fx-991EX calculator is displaying [Dec], it means it's in Decimal mode. To switch back to normal calculations, press the MODE button and select the desired mode, such as COMP for computation or MATH for mathematical functions. I think this will solve your problem
1/5/2024 2:27:36 PM • Casio Office... • Answered on Jan 05, 2024
2answers
How Can POS software increase Profit?
Retail pos software one of best thing to maintain your store inventory properly. Because if anyone inventory incorrect by mistake then you can lose bing amount.
1/4/2024 6:12:10 AM • Casio Office... • Answered on Jan 04, 2024
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
1/2/2024 8:14:22 AM • Casio Office... • Answered on Jan 02, 2024
How do I reset the HR-100TM Casio printer back to original setting
There is a reset button on the back of the Casio. If that does not work, you may find an alternative method in the manual. CASIO HR-100TM USER MANUAL Pdf Download ' ManualsLib
11/2/2023 5:31:01 AM • Casio Office... • Answered on Nov 02, 2023
Casio FX-570MS 2nd edition calculator. Solve s28 to show answer in terms of 2sqrt7 not decimal.
Question edited for clarity and toss in some CAPS. Maths is important, but ritten English is more importanter :>D No idea what any of that means :>/ But this appears to be the answer. Our Maths Expert just retired from Fixya. https://www.google.com/search?q=Solve+s28+to+show+answer+in+terms+of+2+sqrt+7+not+decimal ..
10/10/2023 6:33:58 PM • Casio Office... • Answered on Oct 10, 2023
Can I omit printing the time on the Casio HR-170RC?
On Page 2 apparently not. It is a very basic machine. You can turn printing off altogether. https://support.casio.com/storage/en/manual/pdf/EN/004/HR-170RC_200RC_WA_EN.pdf ..
9/27/2023 5:07:33 AM • Casio Office... • Answered on Sep 27, 2023
Casio fx-300ES Plus Scientific Calculator Logo
12 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
screen broke
  • Office Equipment & Supplies
