20 Most Recent
Samsung GT-S5300 Galaxy Pocket Unlocked Black Questions & Answers
Country code
contact customer service for Samsung / or Samsung technical support
GT-S5300
This could either be a software problem or a viral attack or maybe due to the internal memory is clogged up. Try free the phone from some applications you are not using to free up some internal memory. if that didnt help, kindly take it to a samsung service center for trouble shooting. Cheers
WHAT DO THEY MEAN BY SAYING CONNECT THROUGH ADB
Android Debug Bridge
This is the literal meaning of ADB. Though at first glance it doesn't appear to tell you anything, it actually does. It's a "bridge" for developers to work out bugs in their Android applications. This is done by connecting a device that runs the software through a PC, and feeding it terminal commands. ADB lets you modify your device (or device's software) via a PC command line.
If command line syntax confuses or intimidates you, have no fear. For most average users, the only time you'll need to use ADB is when you have step-by-step instructions in front of you
HOW: Samsung galaxy pocket unlock ,IMEI 354954054093659?
Hi if you want to unlock your samsung galaxy pocket s5300 mobile from network lock then code is the best solution to fix it .You can purchase code from sites like
TheUnlockSpot.com they are rendering unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ....
I can't open my samsung gt-s5300 i have entered my gmail and it is not responding
Connect your device via USB cable and enter those commands through ADB:
adb shell
rm /data/system/gesture.key
Reboot your android device and now supply following commands
adb shell
cd /data/data/com.android.providers.setting-s/databases
sqlite3 settings.db
update system set value=0 where name='lock_pattern_autolock';
update system set value=0 where name='lockscreen.lockedoutpermanently';
.quit
Restart your device and it It will accept any pattern lock.
it this dosen't work, do a reset:
power off, hold Volum UP+home buttons while power on, select reset
(U will loose your contacts, sms ...)
Too many patern atempts
adb shell
