20 Most Recent Cybernet Systems CyberPower 625AVR (cp625avr) UPS System Questions & Answers
My 685AVR trips itself off immediately after being
Raymond,Replace the battery and that should do it. If it's a 12v 7ah battery then you can buy one for 20USD w/ 1 year factory warranty.If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
11/4/2013 9:50:34 PM • Cybernet Systems... • Answered on Nov 04, 2013
Manual
My Cyber Power 685AVR needs to be charged again as my little grandson pushed the butten and ran it down. I've tryed to charge but it's doing nothing . do I have to hook it up another way to charge, and Do I turn it on when chargeing ? please help me if you can !! thank you so much.
4/14/2013 10:21:44 PM • Cybernet Systems... • Answered on Apr 14, 2013
If the battery is dead,
If you still have your dead battery connected it will work as long as there's no power loss, there are rare cases this won't happen, you can replace the damaged one for a motorcycle one or even a car battery as long as they're 12 volts and polarity setup is right, inverse polarity will kill the UPS so be careful.
5/13/2011 1:29:44 AM • Cybernet Systems... • Answered on May 13, 2011
Nececito la bateria para cyberpower 625 avr la
http://www.osibatteries.com/showproduct.aspx?ProductID=9521&SEName=cyber-power-office-power-avr-625avr-ups-system-battery
Here is the replacement battery. Open the unit, disconnect the old battery, connect the new battery, and put the unit back together. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2/22/2011 2:26:45 AM • Cybernet Systems... • Answered on Feb 22, 2011
5answers
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
10/23/2009 3:35:10 PM • Cybernet Systems... • Answered on Oct 23, 2009
2answers
Power light is out. Is the unit dead?
Atypically if this is an older unit what you have is an issue with the battery. It will no longer hold a charge.
You will nee d to go to the vendor site and look for a replacement battery.
In some cases it may be less headache and cost just to buy a new one.
10/22/2009 9:54:11 PM • Cybernet Systems... • Answered on Oct 22, 2009
Need to copy an iTunes library onto another iPod
It is better to just copy the music to her computer and dowlad and insatall itunes. If she wants all the music just burn a back up and just open i tunes on the other computer and insert disc which will be copyed to computer.
1/3/2009 9:05:30 AM • Cybernet Systems... • Answered on Jan 03, 2009
Shutting down computer
You need a new battery. A battery store such as Batteries Plus can help you. Many Ace Hardware stores will order one for you and in fact, Radio Shack has the most common battery types in store or can get it for you. If you go through Cyber Power you will pay the highest price.
Hope this helped you.
Regards,
Worldvet
Please don't forget to rate all our solutions on Fix Ya.
7/3/2008 12:05:42 PM • Cybernet Systems... • Answered on Jul 03, 2008
I got lucky with my cyberpower 1000. Found that the black wire from the outlets to the board was not tight enough. Squeezed it a little with my pliers, and it works now. Don't worry about the on-plug falling out, you can push it in from the outside when you're done.
3/27/2008 9:50:17 PM • Cybernet Systems... • Answered on Mar 27, 2008
Wiring Fault light
You can download the manual from the link below: http://www.sourceresearch.com/cyberpower/cyberpower-pdf.cfm?PdfPage=625_Manual.pdf The "wiring fault" could be serious, as per manual: "This LED indicator will illuminate to warn the user that a wiring problem exists, such as bad ground, missed ground, or reversed wiring. If this is illuminated, user is advised to disconnect all electrical equipment from the outlet and have an electrician check the outlet to insure proper ground." I would turn the UPS off, unplug all equipment, wait 10 seconds, reset the circuit breaker (if tripped) and turn the unit on. If you still have an issue then it's probably fried! Have you had any thunder storms or electrical power outages recently? Check your house insurance because it may cover a replacement unit. Please update the question & let us know if the information given was useful to you - Good Luck!
3/9/2008 8:02:00 PM • Cybernet Systems... • Answered on Mar 09, 2008
Will not power up
1. Check the little button on the power supply: is it on ?
2. Take out wallplug, wait 10 minutes, then check all power connectors. Press all thight on to the socket, also on motherboard itself.
Try again.
8/16/2014 6:40:55 PM • Cybernet Systems... • Answered on Aug 16, 2014
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered Yesterday
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered Yesterday
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 2 days ago
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
Cybernet Systems CyberPower 625AVR (cp625avr) UPS System Logo
20 questions posted
Top Cybernet Systems Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cybernet Systems Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cybernet Systems Computers & Internet
Most Popular Question
685avr trips itself off immediately
  • Computers & Internet
