20 Most Recent
Ubi Soft Entertainment Prince of Persia: Warrior Within Questions & Answers
I NEVER HEAR ANY MUSIC
HAI vishal its because the game you have is a rip game.It means they will delete the sounds inorder to get the size reduce .if u wanna fresh one you can download it from www.torrentz.in
6/24/2011 4:03:31 AM •
Ubi Soft...
Answered
on Jun 24, 2011
My pc restarts while playing prince of persia;warrior within
you do not have the required pixel or vertex shader to run it.Now if u dont here's a solution:go to the folder of POPWW and find hard ware setings keep serching until u find pixel shader and vertex shader.Now set them both 2.0 or just vertex shader and now try.the game may be slow but it will work.reset this back to 1.4 after you pushed keileena in the portal and it should be fine but save after u push her.
3/31/2011 2:53:59 PM •
Ubi Soft...
Answered
on Mar 31, 2011
How to run this in
Can't play this on a pc. It is for the PS2. Want to play on the pc, then you'll have to buy it for the pc.
Also, unless they've patched it, you won't be playing on Windows7.
Look at top requirement
PoP:Warrior Within
System Requirements:
- Supported OS: Windows® 98SE/2000/XP (only)
- Processor: Pentium® III 1 GHz or AMD Athlon™ 1 GHz
- RAM: 256 MB
- Video Card: DirectX® 9-compliant graphics card (see supported list*)
- Sound Card: DirectX 8-compliant sound card
- DirectX Version: 9.0c (included on disc)
- CD-ROM: 16X CD-ROM or 4X DVD-ROM
1/10/2011 1:35:41 PM •
Ubi Soft...
Answered
on Jan 10, 2011
Same problem
blame the makers of the game it's not your ps
7/17/2009 2:54:18 PM •
Ubi Soft...
Answered
on Jul 17, 2009
Reaching birdman enemy
Try to keep him away from the walls otherwise you will have a harder time
attacking him. Do the same as you did previously until you finally defeat
him.
9. Wall run up to the button on the wall to the right and go into the gate
that opened up.
Scene
Note: If you have the Crowmasters sword you can make quick work of the
minions in this next room attack them with secondary attack (with triangle)
10. Wall run to the curtain to your right and it will automatically slide you
down it when you touch it. Fight or avoid the minions here. Face the wall
that you came down and climb up onto the stone slab behind you. Run up the
pillar to your left and then shimmy left. Climb up onto the ledge you reach.
Follow this walkway straight and then to the right. Wall run along the wall
to your left over the doorway and you should land on a narrow ledge. Drop
down (Circle) and shimmy to your left. When you reach the end drop down
(Circle) twice. Follow the walkway behind you and wall run along the wall to
the right to get over the gap. Go through the doorway up ahead and go to your
left. Be sure you have collected all the Artwork and picked up all the
weapons you could to add to your weapons gallery before continuing on because
you don't want to come back through this portal again (I say this mainly
because I have noticed that the game tends to get kind of glitchy when you go
back through a portal that you really didn't need to go back through). Follow
this path through a doorway of water. Use the fountain in this room to
heal/save and then go farther into the room.
7/9/2009 9:30:04 AM •
Ubi Soft...
Answered
on Jul 09, 2009
