20 Most Recent
Bosch AHS 45-16 Electric Hedge Trimmer Questions & Answers
What is the best way to sharpen bosch AHS 45 16 HEDGE TRIMMER
Please understand, if you do, you may well start a business!
You will have to take it all apart, and then take either a file or a grind stone and resurface the blades.
I know you can learn this skill, if you do not know how, but this time it will take you to do it right will be hours, and if you charge a reasonable rate to do this for others, you may find it cheaper to buy a new one!
You may be able to find a web-site by looking on-line that will tell you exactly you to do this.
God bless your efforts.
My hedge trimmer has a faulty switch
Hi Bob:
First, make sure the power supply cord is connected with power at the tool.
Since it's already broke, you really can't hurt it so you get to play if you're into it.
Disconnect from power supply!
Try to determine if something is stopping the switch from moving far enough to function.
Dismantle until you can get the switch out. Try to clean the switch terminals and check the function with a continuity meter.
If you can't get it to work, see your local dealer about getting a replacement part.
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
I have Bosch hedge trimmer AH15 63-16C which has
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
I want to know capacity and specifications of yellow box capistor present in input supply of my Bosch aquatak 10 pressure washer?
Weight: The Aquatak 10 weighs 6000 grams, ensuring stability during use.
Maximum Pressure: Unfortunately, the specific capacity of the yellow box capacitor in the input supply is not explicitly mentioned in the available manuals. However, I recommend referring to the official user manual for detailed technical information.
Motor Power: The motor power of the Aquatak 10 is 1500 W.
Maximum Flow Rate: The maximum flow rate is 350 liters per hour.
Inlet Water Temperature: The pressure washer can handle inlet water temperatures up to 40°C.
Detergent System: It features a high-pressure foam detergent system.
Pump Type: The pump is a 3-cylinder all-metal pump.
Cable Length: The power cable is 5 meters long.
Hose Length: The hose length is also 5 meters (made of PVC).
Nozzles: It comes with a fixed fan jet nozzle.
Regarding the oil leak issue you mentioned, it's essential to address it promptly. Here are some general steps:
Turn off the pressure washer and disconnect it from the power source.
Inspect for visible damage or loose parts.
If you suspect a broken bearing, consider contacting a professional technician for assistance.
For the oil leak, I recommend not attempting to fix it yourself. Contact a qualified technician to address the problem.
Please note that the Aquatak 10 is an electric pressure washer and does not require oil replacement, as it does not have an oil reservoir. If you need further assistance, consider reaching out to Bosch's customer support or a certified tech.
3/11/2024 7:42:53 PM •
Bosch Garden
Answered
on Mar 11, 2024
